Useful tools that others don't use!
Dave455
Sussex, England
Well folks!
Been on the forum for a while now! Enjoyed the chat and got some useful advice! (Cost me a bit too, but there you go!)
I reckon now's the time to try and give something back!
Reading the various threads it's apparent that there are some tools that I use regularly that others do not!
So, I thought I'd start a thread where hopefully folks will contribute details of any useful tools they've discovered, or maybe used for years, but others may not!
I'll kick off with a few examples of my own!
1) Parallel Action Pliers
These are made in the U.K. by Maun, and have been for decades, but the design is definitely of U.S. origins. The first pairs made it to the U.K. in the 1930's and were marked "Bernards Patent". Not sure who the original manufacturer was, but they were, and still are, seriously useful!
Anything with parallel sides that you want to hold is gripped better with this style of plier. If you want to manipulate a part there's much less chance of it slipping, and there is no better tool for removing or inserting roll pins!
Many sizes and styles are available, including cutters, but the ones shown are most useful!
2) The Ratchet Unit
These were very popular once, less so now there are so many varieties of ratchet handle, but they still offer many advantages!
They are of much heavier construction (thicker ratchet and pawl) than the mechanism of a similar size ratchet handle, so can generally be used safely with a breaker bar! If you have a couple of breaker bars you have two different lengths of ratchet!
More usefully, you can use them between an extension and a sliding T to make a ratcheting T. My most commonly used combination around the workshop!
3) The Q Max Cutter
Don't know what these are generally known as in the U.S. , but I know Greenlee make something similar.
They were originally developed in the U.K. for radio work where neat holes needed to be punched without power tools. You drill a pilot hole where you would like the large hole centered, assemble the punch either side and just wind in the cap screw! The clever design of the tool punches the centre out of the hole progressively, leaving a perfect hole with no sharp edges!
A great tool, inexpensive to buy, and available in all manner of shapes and sizes!
4) The Surgical Scalpel
We all do a lot of cutting and trimming, and the most useful tool I've found for this is the surgical scalpel. Cheap to buy, with blades that hold a good edge, nothing from the "craft knife" makers comes close!
I use the regular size handles all the time in carpentry for trimming up a freshly sawn edge! In metalwork I use the larger "Swann Major" (the name given by it's British maker, but I'm sure there is a U.S, equivalent) all the time for marking out, and even for de burring!
5) The Screw Starter
Very common in the aviation sector, but rarely used elsewhere, and I don't know why not!
If you are unfamiliar with these, they clamp into the head of a screw that's difficult to reach! Even if you can only get your fingertips to a screwhole, you can get the screw started safely without any risk of dropping it! As you wind it in, the screw starter automatically disengages!
creativecars
Indiana- where horse and buggies still roam
#5 the screw starter was popular when slotted screws were more common, but since phillips became more common they have went away. Dad used to carry a Craftsman that had a magnet on the other end, the magnet was used more often, except when installing points in a distributor.
motormitch
Austin TX
Here's a couple. First is a punch and chisel holder and second is a battery cable terminal piler.
wittycow
Bluffton, SC
This is been the best $8 I have spent in a long time!!!
Ign
Butte Peak ND
Example 1 got me thinking of Robo Grips :D
Craftsman holiday gimmick department, is that you?? Just kidding!
richfinn
Leeds, Yorkshire, England
Battery carrying handle/strap (save your back)
Ohms law calculator (I use the I-phone version)
Brake caliper file (Cleans the pad contact points)
Spark gap tester (no one in my team had ever seen one)
Impact driver (the type you hit with a hammer)
Load pro test leads (great time saver)
Hub cap "yankers" (hook through holes in plastic trims to avoid using a lever)
Brake spring pliers/hold down tool/brake drum gauge
Vacuum gauge (no one I know uses these anymore, except me as I know how to read it :))
Hub/grease cap pliers (I hate it when people damage them)
I've got loads of stuff the other mechanics laugh at, but I don't care I earn more than they do :)
scaron
ypsilanti, michigan
I have a pair of "Bernard's pattern" pliers in my old tool collection, they are nice enough but don't get me wrong, Klein and Knipex have improved on the plier in the last 70-80 years... :) I also do keep an X-acto knife in my electronic/telecom bag, it's not quite a surgical scalpel, but pretty close...
Probably the oddest pair of hand tools I carry is for manual wire-wrapping of ~22-24 AWG telecom wire onto 400 type shelf backplanes. I suppose you could use it to wire wrap ~22-24 AWG wire on other things but that's why I got them. I have lots of other specialty telecom and electronic tools that an auto mechanic would probably find unusual but they're really not so uncommon, it just depends on the field in which you work. Examples include my crimp tool, my 66/110 punchdown tool (manual and spring-loaded), my banjo adaptor, my **** set, my tone generator and probe set, and that's not even getting into my electronics lab :)
In the garage, I have a few proprietary tools that make it vastly easier to disassemble a Puch E50 moped engine. This includes a flywheel lockup tool, clutch puller, flywheel puller and a crank bearing installer (actually, that's just a carefully selected piece of cast iron pipe, LOL).
motormitch
Austin TX
Jacobs Chuck for an air impact gun in case you need a drill...
nanofrog
I have a pair marked GFC, also made in England. Extremely useful.
I use an X-Acto. Probably not quite as sharp, but quite useful, and blades are easy to find, particularly if needed the same day.
I'd add:
Medical/dental tools such as hemostats, probes, dental mirror, and wax carving knives.
Spudgers
Loc-line coolant hose for making a useful set of "helping hands" (or anything that you could use that third arm nature didn't provide). ;)
MrMark
Southern Cal.
What is different about a brake caliper file from a regular file and where can I get one?
The only one I see for the US is a Stalwille for like $60! from Toolsource.
The caliper mounting bracket on my Merc has some irregularity and the pads heels hang where they ride on the mounting bracket and make noise when braking on slow turns.
jeffmoss26
Cleveland, Ohio
I have all of those tools, in multiples :D
motormitch
Austin TX
Here is a cool one. It is a bi-directional ratchet adapter for power bars. Push in and turn, release and turn.
PCO6
Newmarket, Ontario
Battery terminal/clamp EXPANDER !
I have't seen one of those since I used to install batteries at Sears over 40 years ago !
That's correct and if you were installing batteries for Sears I'm sure you learned that there's right away and wrong way to use it. It's pretty easy to break a cable clamp if you "expand" the non bolt & nut end of the clamp. Don't ask me how I know that.
richfinn
I dont know where you would get one in the States or even if USA calipers are SAE or Metric???.
Anyway mine is 10mm wide with a coarse diagonal pattern and its very good at removing rust and **** quickly.
Its seems to fit all euro calipers.
zakmartin
Seattle, WA
I use a Pro-Fit dash trim removal tool every time I'm separating plastic parts in my car. It keeps the garnish from getting scratched. I have about 5 of these things spread around my garage. What I like about it is when it gets dull, you can carve it with a box knife until it's sharp again. I always cringe when I see someone separating panels with a screwdriver.
MrMark
Southern Cal.
Thanks! This would be for the mounting bracket where the ears of the pads ride.
HighPlainsWrencher
The only thing that I can think of off the top of my head are torque adapters. I use them all the time to get to nuts and bolts that are hard to get to. They have saved me countless times from having to take multiple things off to get to the bolt or nut. Which is a huge plus when you are trying to beat flat rate.
SlappyWhite
Upper Canada
Dental floss. While I am sure people don't floss enough... I use it to hold washers on bolts all the time, specially when they would fall off before you get the bolt in place. Once a couple treads are in it can be pulled out. Also works good for gaskets etc. use it to hold them in place and slide it out before tightening.
cheechi
Triad, NC
Could that double as a hammer drill then for masonry?
Hammer drill and impact actions are opposite. Hammer drill is in & out in the axis of the drill bit. Rotary/impact is rotational around the axis of the drill bit. You can't turn a regular impact gun into a hammer drill, period.
Rotary hammers have both a chiseling (hammer drill) and impacting action combined. That's the tool you want.
AV tinker er
SoCal
Ahh, thanks for the info. I have little need for a hammer drill, I don't do much, if any, masonry work.
jfcasey
New Hampshire
Its pretty simple but I work with a lot of guys who hate and refuse to use air ratchets. I freaking love them especially my mini 1/4" aircat.
71Datsun510Wagon
Regina, Saskatchewan, Canada
motormitch
Austin TX
Guess what this is used for....
