Hey guys, new to the forum here and have been trying to learn as much as I go. I am hoping people can chime in and help me complete my in floor heat setup before hell freezes over (Winnipeg Canada).
Here is my garage Specs:
24'X36' with 9.5' Ceilings. Walls and Ceiling all done in OSB Board.
3" Rigid foam under the slab
R19 in the Walls and Will have R40 blow-in in the ceiling
I currently have 4 zones of pex in the slab, 3 are around 210' and 1 is around 230-240'...
I currently have ordered:
Noritz NRC98-DV-NG Direct 9.8 GPM Indoor Condensing Vent
Noritz VK3-H-PVC Concentric PVC Horizontal Termination
Noritz IK-WV-200-1-SW Isolator Connection Kit with Relief Valve
Noritz NC-1 Residential Condensate Neutralizer Kit
Little Giant 554425 VCMA-20ULS Condensate Removal 1/30 HP Pump with Safety Switch
Now my problem is I am actually stuck as to what else I need to order as well as set up. I DO NOT have a water supply that runs to the garage, I do not know what type of pump to get, not sure on what kind of manifold to get as well as I am completely lost as to what else I would need to complete the system and what order to hook everything up in.
So if you guys could please help me out it would greatly be appreciated. Thanks
