I have a full sized set of torches but always rented tanks and since a move a few years back have never got around to setting up a contract and getting tanks.
Just pulled out the cart...plan was to check things over and finally get them back into service. Hoses are looking a bit tired and should probably replace them. So...need to spend some cash there. Suspect if hoses are tired then the seals in the regulators may also be a bit dried out.
Since I got a plasma cutter, the overall need for at least cutting is less but sure handy to have even if its just for that once a month or two need. But by the time I buy replacement hoses, buy or rent tanks I'll probably be at the price range of a set of portable tanks complete with torches, regulators, hoses and the holder.
Any suggestions on portable in general or brands to stay away from? What is the Tractor Supply set like as far as quality and value?
Gordon S.
Gordon S.
In other words, as the level drops and there's more "free space" in the tank (above the liquid level) there should be more gaseous acetylene to maintain the same pressure. Kinda the same reason you can't use a pressure gauge to judge level in a liquified gas tank worth squat.
The guy that taught me OA welding served in WWII (to give age), always told me of the 1/7th rule. I figured if he lived that long, it must be pretty safe.
