7th Kahuna
Hey guys,
This weekend I have to do an semi-emergency gas line repair. A crew (not mine) with a backhoe got a little too close and left me with a pinched water line and a gas line with a slow leak. They repaired the water line (more or less) but that was it.
Replacing the water line is no problem, I've been sweating copper since I was in my early teens. I've run gas indoors. I have been trying to quickly get up to speed on underground gas however (low pressure / customer side). I intend to do it in iron. I know to use coated but I could use some help with the joints. I have seen plenty of taped joints that don't look like they are very water tight. I picked up a can of Christy's Prime-It! Pipe Wrap Primer. Anyone have experience with this product? Is it the solution to getting the PVC tape to hold better?
I was actually giving some consideration to spraying auto undercoater or even hand applying liquid asphalt at the joints.
In my research, I think somewhere on this site, I read that if the entire pipe is coated you need to use a Magnesium anode or the steel will actually rust away faster than if you just buried it raw. I haven't seen one installed before. Is this common? Is it something that could be added after the fact?
Also is there anything special to do where the line daylights before entering the house. I have noticed in situations where the meter is above ground, the gas company sleeves the high pressure side but I am not sure what is going on there.
Can any plumbers out there offer a final word?
Thanks
Thanks
. The contractor replaced a section of the water line in order to get the water turned back on and the water company came out and replaced the meter. As far as anyone is concerned they are done, but I know they have just delayed a bigger problem.
I assume the connection to the riser was at 90°.
In this case its smellivision. At least for me. Actually both existing lines are covered with 2 ton steel plates so I can't really see much of anything. The new line is taking a different route as there in now a tree in the way of the old one.
