If you leave the 3 prong outlet as is the ground needs to be removed. That's an ungrounded outlet. You don't want a bare wire being used as a neutral. Just disconnect the ground from the outlet and tape it up and push it to the bottom out of the way.
The metal of that receptacle needs to be bonded, so the OP would not push it out of the way.
