Hephaestus29
Is there a thread for phase converters on here ? Rotary & static. Thanks
+1 on practical machinist
There is ia full section on VSD and converters
Too bad the guy that runs it is a pompus ***.
BTW, its VFD, your fingers got out of sequence there.......
VFD word of warning.
if you run the output of the VFD to a machine, you must go directly to the motor. You can not use any switches or interrupts (starters, heaters, relays) in line. Interrupting the power will toast the output IGFET/ MOSFET/ transisitors.
You have to hook up your forward / reverse to the terminal strip of the VFD.
