Old Craftsman 150 Drill Press
Is the owners manual original (Or a download), and do the model No's map properly? (the whole No.; not the first three digits, as that is simply the MFG code...)
Is the table one that can be tilted?
EJM02
Looks killer so far!!
I'm in the middle of restoring a 100 model at present. I wish I was clever enough to come up with the 'poor man's lathe' as you did.
My solution to the column rust was to soak it in a 3" PVC (capped on one end obviously) filled with vinegar and a little table salt. Overnight the surface rust loosened to the point where an angle grinder with a cupped wire wheel did the trick.d
D
doan
Frisco, TX
Now that painting is done, I had to fab some parts - pics below.
For parts I still need new bearings, and a 4-speed pulley for the motor. I saw a thread with the bearing details, but I don't remember where - will have to do some digging.
Motor Mounts from 2" angle iron
Internal light
Back plate for motor wiring (original was gone), and provide a place to anchor the flexible conduit.
Cut slots in a standard handy-box and attached it to the post with hose clamps to house the switches.
D
doan
Frisco, TX
That's how i started, I didn't use PVC, I just made a paste with barkeepers friend and kept it damp. That got most of the rust. then I got tired of the angle grinder and scrounged up the stuff for the red-neck lathe.
Looking good!
Suggestion for the light bulb: You can gen small flood or spot lamps and get better light than just an regular light bulb, and use a lower wattage to get it. IIR, I had a 40 W in there
Bill Ramsey
Tulsa
Looks great, doan. Ready for another 50 years.
BTW, I once took the catalog prices for these old 1950's Craftsman presses and ran them through an inflation calculator. IIRC, it would be like spending $900-$1,000 on a press today, if that gives you an indication of how nice a press these were in their day.
D
doan
Frisco, TX
Had more wobble than I wanted, I went to HF and got a dial gauge. Started at about 0.024". Using a 1/2" grade 8 bolt in the chuck, a chunk of 2x4, and a 3lb hammer, I was able to get the runout to < 0.005". Switched to a 1lb hammer and chased my tail for a while trying to get better, but that as good as I could get.
I'm pretty happy, when I got it it was in bad shape. Before I got the dial gauge I tried to use feeler gauges and an angle iron fence. It was more than 0.060 (about a 1/16) when I started. You really need a dial gauge set up to get really close.
Here's a link to a video with the dial gauge tracking a 1/2" bit just below the jaws.
I'm pretty excited considering where I started.
I also learned the the old crusty belt I'm using is what is causing a lot of vibration. I put a shim between the head and the motor to back off the tension and it got a lot quieter.
Any recommendations on where to get a link belt? HF has 5ft for $25.
SNIP
Unless they changed suppliers, the HF link belt is made in USA and it's a well regarded belt. A LOT of guys that work on the Craftsman/Atlas/Clausing mills and lathes use em.
454ragtop
Carver, MA
I personally don't like link belts, especially on something like this where the belt comes right off without disassembly. I think they wear aluminum pulleys more than a std belt. Might think about a notched AX series, much better IMHO. Do you have the dimensions of the 4 step pulley you need, including motor shaft size? I have a few 4 step pulleys, of unknown origin.
Jim
D
doan
Frisco, TX
Jim
So the AX is just like a cogged automotive v-belt?
The motor pulley is 1/2" bore with a set screw, 1/2" belt, 4 speeds from about 1.5" to 5" in diameter.
tool_scrounge
Southern California
Jim
I like the Goodyear FHP cogged belts. The last one I purchased was about $8 with shipping off of ebay. From what I have seen in the technical literature, the cogged belts are about 8% more efficient when running with a pulley <=2" diameter.
D
doan
Frisco, TX
Re: Old Craftsman 150 Drill Press - Restoration Complete
Finally done, just waiting on the 4-speed pulley for the motor. I stole a few good ideas from other posters here including adding the light inside the head and the fence for the table.
Photo Album HERE
markw365
Looks good, now you need the speed reducer pulley. :) Let your quest begin.
bluebolt
Benton LA
I've been lookin... Also thinking about a variable speed motor from a treadmill
Keep your eyes open for the Craftsman variable speed motors too, I have two, one came on my 150 (non reversible) and the other has a refurb tag on it from Sears and is the reverisble one and will go on my benchtop 80
