How to slow down a hand angle grinder for softer cement
pauls_workshop
Indiana, USA - Underappreciated Place to Live!
Please see new thread I started here in tools:
http://www.garagejournal.com/forum/showthread.php?t=225860
For hand grinding of floors for epoxy with an angle grinder, instead of using a high powered one for harder cement areas and a lower powered one for softer cement areas, you could likely use a router speed control to just slow down your higher amp powered grinder as needed to get the job done. This would allow more control of the grinder when you need it to be slower with less power for softer cement areas. I'm going to try this out shortly. - Paul
Baada
Eastern Missouri
Interesting idea, let us know how it works. Might be easier than changing your cutting/grinding tool for the task/substate at hand?????
CNGsaves
KS and OK
Isn't it awful dusty trying to run grinder in that loose cement ?? :D . . :evil:
Now CONCRETE, that would be more firm !! :bounce:
