Home brew oil filter wrench
That is what I was thinking, maybe from special filter.
Possibly a welding ground clamp. Can you post some more pics? What does the screw between the strap hand handle end with?
That was my inclination but It was in a snapon parts baggie
Does it have a part number on it?
Yes, but it doesnt make sense and turned up zero results on google
No its not a brake in the sense it stops something. Its a brake in the sense its used for bending purposes. So i would say that is the replacement handle for a sheet metal brake. the rounded soft metal ******** it would be what would engage the brake "bending hinge" of the machine.
Not an oil filter wrench. The nut inside the band would interfere with the filter when the device is closed.
Yes its a clamp cam handle for a brake. Couldn't think of the name. Like this just a different design.![]()
