Remove rust stains from concrete?
PoorOwner
CA
I have some rust stains on the patio, what's the best way to wash it out?
I did a search and it points to TSP.. going to try that tomorrow.
What about wheel cleaner similar to IronX, or navel jelly rust remover?
77thor
Milwaukee, WI USA
I haven't tried it on concrete but a product called CLR is supposed to remove rust stains.
(Walgreens, Kmart, Walmart, all carry it)
Dale Leeds
Williamsburg
I'd try the Naval Jelly. But rust is really hard to get out of the cement. In the past, I have sprinkled a thin layer of the powdered cement over the rust and let it dry. It is hard to match the color, though. :(
bigbadktm
SoCal
Haven't had any luck getting rust out yet. CLR just doesn't do anything once the rust stain is set.
lilredex
Toronto
Try wood bleach.....oxalic acid. If you can find it.
I have also had decent results from limestone (soup). Take crushed limestone and mix with water. Strain off the water and apply it to the rust. Results do vary though, depending upon the origin of the limestone. Have also tried (garden) lime mixed with water...just not the same.
Maybe there are some chemists out there......
TSP and CLR both duds in my experience. TSP is good in your washer (clothes)...does make a diff.
jkwilson
SW Indiana
For small areas, try making a paste of crushed vitamin C tablets and water. Scrub, let it sit for a few minutes and then rinse well. If it lightens the stain but doesn't remove it, repeat.
kamesama980
columbus, IN
I used muriatic in my garage but I was cleaning the whole floor in prep for a floor coating. It'll get the rust out by eating the outer layer of concrete the rust adheres to. The result is a cleaner patch where it was applied OR if it's mixed weaker, won't remove anything.
bdamico
what happens when you make a poultice and iron out? That's what you do to with certain stone rust stains
