Jeff May
Fayetteville, PA
Re: What did you do in your garage today?
rohartman, WOW $5300 I had a cow when I paid $500 for an AIM system for my kart.
I'm not really complaining though, AIM has tremendous data logging equipment. I really like the unit I got for my kart.
I guess quality isn't cheap...
JohnK007
Downers Grove, IL
Replaced the Fuel Pressure Regulator in my son's '05 Chev Cavalier. Thought I had the fuel line depressurized. Found out otherwise when the regulator came off the fuel rail. Got sprayed right in the puss. Lesson learned!
RivennHewn
PNW
Started a new table.
Glued, screwed, and clamped.
Duker
Livingston, TX
Made a little progress on the workstation this weekend. One of the dual 56” benches is complete and hopefully the corner cabinet below will be done by tomorrow.
Also started to patch some walls in order to paint so that I can start to set the benches in place.
Red Leader
Denver, CO
I am constantly using the wet vac from the same problem. I hate it.
I decided to clean up my garage walls after collecting banners, photos, decals and a lot of other **** over 15 years. I kept anything that meant something to me and put it on a couple of cardboardish panels that came with my Crapsman box a couple of years ago. Then I covered it with lexan. Now I still have the few things I wanted to keep and it should be much easier to clean the walls periodically. I did this all last week before my wife had her back surgery this week.
Really like your air hose setup.
That is looking like a really cool project.
I did some more deep cleaning and rearranging of the garage. No photos yet, but it is looking a lot better. I was able to reclaim one entire wall back! 95% done out there with the cleanup.
evobuilder
Tustin, California
I am doing something in my garage constantly.... but this week more than ever. See... I have a 1 car wide by 1.5 car deep VERY old garage (my house was built in 1910) so you can imagine,
I have never owned large garages and I am very good with small spaces, and in my garages, I have at least a couple motorcycles, a street rod or other project, rollaways, bike lift, drill press lathe, sander, bench, etc. 20+ years of single car garages has made me a space pro :)
I recently sold my lathe so I can make room for a 2 post car lift.... when you have small garages, every square inch is valuable real estate.
So... what did I do in my garage today? I have a TON of old nasty wood in my rafters... something I never wanted to deal with, and today, I decided to deal with it. I figure the rafters are valuable space I have never used, so by the time the weekend is over.... I will be storing **** up high, a place I have never thought as usable space... until now.
I will take pics and post.... or even better, I'll start a thread in the gallery.
Ohh... and I am rewiring the whole thing on Monday. So... lots going on in the garage today!
justanengineer
Motor City
I remembered how little I enjoy working upside down underneath dashes and how old I am. Luckily, bc of the winter weather I had a few extra layers on so it wasnt too terrible. Not sure which will have me more sore in the morning, working under the dash or shoveling snow.
In reality, I popped the dash apart on her 68 Mustang, chased down an issue with the oil pressure gauge wiring, shinied up a few parts, and ran the engine for a few minutes til one of the carb spacer gaskets started leaking.
RalphInCA
Wine Country, OR
I learned, once again, the absolute joy that comes from working on my car using good quality mechanics gloves.
Why didn't I discover these twenty years and a thousand ****** knuckles / burned fingers ago?
Outlander
Quebec, Canada
Got all the current stickers on both snowmobiles ( registration, trail permits) gonna ride tomorrow!
:rocker:
My ATV club is being pounded with requests about opening trails. Today is the first day our land access rights kick in and we are getting crazy amounts of snow. Enjoy, and ride responsibly!
This weekend I had to change the thermostat in the basement of the lake house. My feet were freezing so I went down to investigate and sure enough no heat. Got to it just in time, temp was around 5*c and I my pipes are all exposed. Used a space heater to accelerate the process. Boy did I notice the difference this morning when I work up!
wrenchMONKEY_
Swapped out the alternator on my 06 Tundra, 155,000KM and she was pooched.
TheClaw
Chicagoland
Snow tires for the X5.
Fabricated, painted and intalled a fire extinguisher mount for the Porsche.
crewchief888
NW indiana
changed the starter in my '00 sierra out in the driveway,
by the time i was done it warmed up to a balmy 22F
:beer:
Thumper68
Duluth MN
Put the new wheel chair restraint system w/ shoulder and lap belt in my sisters van.
Fixed the rear door, the side door contact points and replaced the headlight switch on the same van, I need to keep this van in good shape since it's in my name.
Doug Arthurs
Ontario
I made these adjusters. They are for a Hyd-Mech H28 bandsaw. I single point turned the 1"-20 thread.
Jimmy_B
Pulled the wheels off my old Crown Vic so I can get the new tires mounted tomorrow.
Dan in Pasadena
Pasadena, CA
I put some things away that I had used last weekend at my daughter's new house. A painted the entire thing inside.
Does anyone know an easy way to remove latex overspray from tools?
fatboy99
Indiana
Changed the ignition key cylinder of doom on my 2000 Ford Focus !! It went way easier than I expected. The new key cylinder kit I got at Advance Auto is a better design so hopefully it will last longer.
CudaChick1968
Member Emeritus
Northwest Tennessee (38230)
Though when I'm done I'll have made enough to probably fill up the 7-footer in the shop lol, I restrained myself to the small oven in the kitchen and spent the whole day baking Christmas cookies. Not done yet (just taking a short supper break), I've got 3 pounds of milk chocolate fudge and five different batches of cookies done so far.
The Cookie **** will follow shortly. :D
Those close enough to PSC are welcome to stop by and pick up a plate -- just give me the head's up so I'll have one ready.
Jeff May
Fayetteville, PA
Been remodeling my cargo trailer the past few weeks. Spent today just putting tools away and vacuuming up the saw dust and dirt I created in the shop.
Time now to start painting the cabinets and walls in the trailer. Will do the doors in the shop.
NUTTSGT
Northern Central Ohio
Re: What did you do IN your garage today?
I worked on the granddaughters toybox for Christmas, adjusted the garage door and put a little insulation in the attic.
BTW, I edited the title of the thread and put "to" in caps to try to prevent confusion between these threads
Scott65
Green Bay, WI
Friday night- installed new plow prior to the a start of 24 hours of light, steady snow.
picture.php
Sunday afternoon- washing cars to remove all of the salt and snow.
picture.php
madison069
Monroeville, PA
This week had an backed up sewer pipe and in the process I found out the drain in the floor was attached to this sewer pipe, but because the drain was rusted and full of dirt I didn't smell anything. Well, when the cap came off it crumbled in my hand and I was left with a poor sealing cap on a drain I didn't really need, specially when it's smelling the garage up. So I took a ABS flat cap and put silicone in the inside to create a silicone seal, but I didn't put it on the drain yet. I'm letting the silicone cure and when it's cure I'll press it over the pipe that's sticking up in the drain to make a tight seal.
Hope this works, but won't get to try it til tomorrow when the silicone has finally set.
383 240z
Findley Twp. Allegheny Co.
I ran in, grabbed a book of drawings for parts I need to machine. Ran back into the house to study them. Was pretty cold at the time.
I'll be heating the machine shop tomorrow as the wife is out of town and I have the day off. Going to make some new parts. I hope to get enough done to warrant taking and posting pics. Keith
TheClaw
Chicagoland
Ooh. Pics of extinguisher mount?
I've got a square plate under the seat to reinforce the the whole thing. I think it's going to be shaking quite a bit and didn't want it to rip through the fiberglass in the bottom of the seat.
image by theclaw900, on Flickr
Jeff
zmotorsports
Northern Utah
Jeff
Very nice job on the fire extinguisher mounting bracket.:thumbup:
Mike.
zmotorsports
Northern Utah
Last night I replaced all of the glow plugs in my 2006 Duramax and then started to break down my 2010 Wide Glide for some preventive maintenance and some cosmetic changes.
Mike.
CudaChick1968
Member Emeritus
I packed up Friday's Powder **** for pending delivery to its owner in Ohio and rearranged a few things in the shop to accommodate an ancient but new-to-me Montgomery Ward powder storage freezer. (It was sitting outside my favorite machine shop looking lonely and unused when I dropped off Billy's tractor parts and it got to come home with me when I picked them up.) Anyway, here's the **** ... it's not likely anyone's going to get as excited about the old freezer as I am. LOL
For some reason this pic here -- my first ever custom alternator bracket :D -- is the most accurate color-wise out of the whole photo spread. The Corsair Gold looks MUCH more yellow than it really is but in reality is almost a dead-on match for Caterpillar yellow. You can see the customer's paint sample above the bracket.
And this morning, at long last, I get to start on my first Garage Journal customer's parts. :D Hmmmmm, let me say that a bit louder .... "Hey Larry!! It's finally your turn doll!!" Yeah, poor guy's been waiting on me for awhile. I hope to do it lots of justice.
Hencini
Btw, that looks like Blackhawk in your garage link.
What gave it away, the beautiful scenery or the trash cans for crash barriers?? :lol_hitti
Yeah, as small and antiquated as it is, I have a soft spot for BHF. It favors suspension, momentum and driver skill over HP and it's got some really fun and rewarding turn complexes. Great track to learn on. :thumbup:
I'm living in Memphis now and there's no proper road course nearby that I know of. The speedway here has a couple turns, but from what I've heard it favors high HP cars. My buddy here (in his 415 HP Corvette) keeps suggesting we go. I'm sure I'll get out there eventually, but I miss being an hour from BHF and two from Road America. :thumbup:
Hencini
Jeff
Very cool!! :thumbup:
BMW sold a mount and extinguisher for my car. I've thought about coughing up the cash for one, but lots of guys have done exactly what you did for a very clean install at a fraction of the price.
Hencini
Wow, beautiful work!! :thumbup:
