Detached Shop Wire Size
Bevis
Moore Haven, Florida
Getting some conflicting answers on what size copper wire to run thru my conduit to my detached shop. From my house 200 amp panel to the shop is 65' - 70', I want 100 amp to the shop panel. I have a 125 panel in the shop now, and will put a 100 amp breaker in the main house panel.
So should I run #1 or #2 for the distance / amp ?
JoeFin
NorCal - where the Rednecks Race
#2 awg
Voltage drop: 3.13
Voltage drop percentage: 1.30%
Voltage at the end: 236.87
under 3%
Norcal
Who puts Aluminum in their own house
I figured it for 2 copper
I did, the SE conductors, house subfeed, & shop feeder are all AL. Aluminum is a great way to cut costs,and copper, or aluminum conductors installed improperly will cause problems, bias against aluminum conductors is just ignorance. BTW, #10 & 12 AWG AL conductors are still allowed by the NEC, if anyone was selling it. :shocking::shocking: And no, I would not use it..
Bevis
Guess I could've just went back and reread older posts ... I had a shop rebuild this year, after a neighbor walked away from a burn pile that got away from him. Overgrown lot behind my shop lit up and ran in all direstions... I get a call from the Vol. fire chief telling me to get home and help fight my shop fire :shocking:
Aceman
Eastern Oregon
Since you don't want aluminum, you only need #3 copper. 65-70' is nothing as far as voltage drop is concerned.
3-#3's and 1-#8 green is what you want. It will fly through 2" pipe.
Falcon67
Merkel, TX
I ran 2-2-2-4 and breakered at 70A. Run is 120'. No problems with two AC units, heater, welding, etc, etc.
As wfor who put aluminum in their own house, I'd say people that learn the proper installation requirements to make a safe install. All utility runs to houses here are 4/0 AL. Nobody seems to be having problems with it.
