Getting near time to install heater flue
jmarkwolf
Southeast Michigan
I am about to hang my new Beacon Morris ceiling heater in my new 28ft x 30ft detached garage/shop, and am debating whether to route the flue up, through a 12/12 pitch roof, or laterally through Hardie Board wall siding.
I think the only good option is going laterally, given that the temperature is about 10-20deg F here in Southeast Michigan now. I'm also reluctant to cut a big hole in my brand new roof.
Any words of wisdom and experience?
Highbeam
Mt Rainier foothills, WA
I hate roof leaks. They can be devastating. Anything you can do to avoid a hole in your roof will be good. Trouble is that the side flues can look pretty goofy.
brewchief
If you go out the side you will need to use the stainless pipe instead of B-vent.
I prefer the roof, a properly installed flashing will last as long as the roof without leaking.
I can refer you to a roofer in Brighton who can properly install a flashing even in this weather.
J
jmarkwolf
Southeast Michigan
By all means, please provide contact details. I'm not far from Brighton.
I'd much prefer going out the roof but have no confidence in doing it myself successfully.
6768rogues
Western NY
I have one building with the flue through the roof and another with it through the sidewall. Both work great and I have never had a problem with either of them.
