tools only YOU have
mailpup
Los Angeles
This is a tool for adjusting a Zenith Stromberg carburetor that I bought new in the early 1980s from the parts department at a Triumph car dealer. It is unused and still in the original packaging. I realize the tool is hard to see in the packaging but I didn't want to open the package just for this picture. I bought it for a 1977 Triumph TR7 but the car was sold before I got a chance to use the tool. It's not that unique but I'm guessing not that many people have one.
parnass
Kendall County, Illinois
I inherited this Tri-Tap-Tool years ago from my father in law who was a tool and die maker.
A web search shows a few other thread cleaning tools, notably Klein. I have a different one bearing the Efcor brand with a rubber padded handle.
The handle is marked "Tri-Tap-Tool" and the other side (not shown) says "Mfd. U.S.A." The shaft is engraved with a logo of TTT inside a triangle and the words "Pat Pend" underneath.
I cannot find anything about this particular tool or manufacturer, although an obituary claims Gilbert Nathan Griffith invented and patented the tri tap tool in 1954.
Link: Gilbert Nathan Griffith (1920 - 1983)
The patent number and date cited in the obituary doesn't check out.
A web search shows a few similar tools, notably Klein, and I have another one bearing the Efcor brand with a rubber padded handle.
Parnass, those are made primarily for electrician's and the sizes are all the common sizes used for electrical boxes, switches and receptacles. mostly used as chasers, but I've cut new threads with them. very handy to have. I've not see that particular brand, though. Sears sells them under Craftsman for one.
jayrush13
Lebanon Oregon
Some odd ones today: top and bottom in this pic, (although not many will have 4WR 4LN or 4BN Peterson vise grips either...)
Top: Boker, barrel nut pliers I suspect for cannon plugs.
Those bottom tongs are odd, closed the jaws meet at the tip and get the best grip with something about 1/8" thick in them. That also gets the grips a little more comfortable, as closed they are hard to grip at all, but I suspect these had extension grips at one point? possibly with scissor type loops? (or, what else could those inside grip notches be for? :dunno:
The only markings are: "A.G.5" and in front of that, a three leaf clover? Ring any bells anyone?
Tong faces are serrated finely for grip:
Did someone say Boker USA
View media item 36357
View media item 36356
Here are a couple I think are odd but not sure
Pexto linesman pliers
View media item 36358
and plomb 6502 7/16 x 1/2 8 point DBE o offset wrench
View media item 36359
View media item 36360
Which I think is for 20s and 30s ford mechanical brakes
kool_BOY8323
arizona
ive got an old plomb 1/2 breaker bar. this is a pic off ebay, not mine. I want to get a 3/8 and 1/4 to match it.
never seen a second one in person.
Here is something you don't see every day: Snap ring pliers in the large economy size! Those suckers are almost 16 inches long, The "small" std size pair are for size comparison and yes, that is a GW quarter also for scale...
Is that the 18 or 15 inch version? (Edit: never mind I wasn't looking at the pic when I asked that! Ruler right there!)
here is mine (Swiping the pic from another thread on breakers) The top 2 are also Plvmb):
humber2
Downunder
Which I think is for 20s and 30s ford mechanical brakes[/QUOTE]
Yep. Model A brakes with the straight version, V8 with kinked offset versions.
jayrush13
Lebanon Oregon
Yep. Model A brakes with the straight version, V8 with kinked offset versions.[/QUOTE]
Yep that's what I was told but it more a conversation peice now as my 35 has juice brakes so won't be messing with any mechainicals
Jbullfrog
Avoca, Iowa
I'm going to start taking pictures of some of my oddities. The first is a Craftsman Speeder Ratchet.
A Herbrand Speeder Ratchet with the blue handle on the shaft.
A Blue-Point geared 1/2" knuckle.
zkling
dang! that's cool. never seen a craftsman one.
Dang, I don't have one in my Craftsman collection zkling. Cool to see it.
Thanks guy :beer: Yea I really don't know much about them. It is actually a set of 3, no part numbers. Unless I've overlooked them in the old cman catalogs, I can't find any info on them, and don't know the background story. They work really well, no flimsy plastic that bends. :thumbup: I'm thinking maybe they came in a old bicycle tune up kit. :dunno:
SCscoutguy
South Carolina
That handle is defiantly a Plomb/Proto handle.
rmmiller
Kennewick, WA
None of these are particularly rare but you probably don't see them very often anymore. I figured since there weren't any posted I would toss them into the mix. Although they may not be a "tool" and I couldn't find them at the moment I have some factory paper template from GM for radio component installs on early Corvairs.
Hammell
Canada
Rare anyway, 1/4 and 1/2 inch Snap On ratchets, from 1945.
G1K
Buffalo, NY
I have one, but I made it. I'll see if I can scare up a photo. I lent the tool to my boos as my my TR-6 engine has been replaced with a Ford 302.
Ryan
jakemac
New England
Ryan
:eyecrazy: How the h3ll did you fit a 302 into a TR6 ? :eyecrazy:
I had a Spitfire 1500 years ago and the engine bays were about the same size, just a little taller on the TR6. but no inner fenders in the way on the 1500. The wheels and front suspension shouldn't have let you get away with that. :headscrat
EDIT - I just saw the link at the bottom of your post, I'll have to check it out.
node105
Australia
I think it's a circle cutter for metal or maybe leather. I saw a similar machine in an old shop for building prosthesis and that was used for leather. I picked it up along with a lot of other tools that where going into the dumpster from an estate. I ended up giving the son of the owner $200 for three trailer loads of stuff. I sold a JD lawn mower for $100 as I was leaving with the last load. The man who owned the stuff was a janitor for a school and he had a lot of unique tools and hand made tools too. I'm glad I could save some of it. If there is a heaven then I hope he appreciates the enjoyment I get when I use his tools. I hope my stuff gets saved from the dumpster when I die.
Richard
Looks like a joggler, puts a step in an edge. The serrated edge on the top wheel could be just to stop slippage, but I am guessing it is probably has a shrinking function. Maybe for creating a joggle on a curved edge when making cones. 40 years ago, I did a year or so in an uncle's sheet metal factory, making corrugated iron rain water tanks, hence it looks a vaguely familiar design.
Way too heavy design to be intended for leather ( I would suggest).
Could be wrong of course.
node105
Australia
Think I'm the only one....
A Shure turntable calibration balance. Used to set the downward force on a stereo cartridge after installation in a turntable.
I had one for year, along with the SME tone arm. Gave them to my niece only a year ago.
sawin
Central Maine
Originally Posted by Outlawmws...
Post #168
Perhaps they were used for breaking glass after scoring with a glass cutter.
Notches on the handle used to break off the little "peaks" that remain after using the jaw.
node105
Australia
One from me. A screwdriver ( stainless…) for inserting lock screws in titanium spinal plates.
parnass
Thanks for the insight, Outlaw. I've been using the Efcor version for years, but I was unfamiliar with the TTT brand. Perhaps TTT was a one trick pony. Enjoy the holidays.
thom1968
I was rebuilding my Ridgid 14.4 battery pack with an 18 volt pack from HF (jury still out). I cut away three cells and needed to solder a jumper wire between 2 cells. I had a devil of time soldering wires to the metal connectors which were spot welded to the batteries. I got it done but then remembered a tool my FIL left me. To use the pres-to-heat you put the metal to be soldered between the prongs and press the switch in the handle. a high current flows between the electrodes and the metal heats up. It happens so quickly there is no chance to damage the battery. It's called resistance soldering and you can buy newer, fancier systems, but not this one http://www.garagejournal.com/forum/images/smilies/smile.gif
This may be a big stretch here...
Craftsman mass produced bit screwdriver.
It has the old logo. I think it's the only one I've ever seen with a bottle neck handle.
Ignore the black cap, a previous owner put it on there. The end is threaded underneath.
Anybody have a complete model to compare to?
John Mc
Charlotte, NC
RivennHewn, I know that I am about 5 pages late to the party, but what you have is called a hag's tooth router by Roy Underhill in one of his shows, and yes, there were mass produced versions by big companies.
