sevensandeights
It's cold out right now - we all know that!
I was in my barn and noticed a large puddle of water under my wall mounted Utica condensing natural gas boiler that provides radiant heat to my concrete floor. I removed the cover and found one of the bolts on the bottom of the boiler chamber dripping one drop of water every 3 seconds. The drain had water in it but it looked dirty so I took it off and cleaned it out - there was some sludge in the tubing but the lumen was patent.
The unit is heating fine and keeping up with this cold weather - I have the thermostat set to 55 degrees. Any idea what is going on?
Water in condensate drain (looking from the left):
Water in the condensate drain (looking from the right). The bolt at the top middle of the picture is the one the leak is collecting on (you can see a droplet forming):
Overall system with lower cover off (ignore the yellow funnel - that is how I am dealing with the leak for now):
Overall system with lower cover on:
Plumbing - the condensate drains through the PVC pipe which goes outside and empties into a dry well:
