I recently built a new house coupled with a detached 34x30 garage (pictures here). Looking for some feedback on my electrical and lighting ideas.
The garage has a 100amp subpanel already installed by the electrician. I'll be pulling wires myself and using him, as needed, to hook things up. The garage stores my toys - no heavy equipment now or in the foreseeable future (except for a lift).
For power, I was planning on doing 4 circuits with 20amp breakers (subpanel outlet and garage doors are already wired), 12-2 romex. This should be enough for tools (power tools, bench grinder, compressor, chargers, etc) as well as my Hobart handler welder. Dedicated circuit for the lift to be installed by electrician. Outlet boxes centered at 52in. Is this adequate for power?
For lights, I plan on using all T8. The double stall 'side' has a 10ft ceiling that runs approximately 18ft across. I was thinking three lights 'zones' in this area. The remaining 16ft (the single stall side) has a cathedral ceiling to near 25ft. I was thinking two zones on this (front and back), with the front side also illuminating two T8s mounted to the side walls. This side will have the lift.
See the 'sketch' below (I'm horrible and this sort of stuff). It's pretty much to scale. I've not done ANY lighting calculations, just estimating lights needed off what is in my attached garage the the light output in there. The approximate lighting layout is shown (obviously, i'll actually measure when i put them up).
I'll also have a work bench at the back of the single side (so i can go from bench to engine of car on the lift). I'll probably run dedicated lights over here too (on a switch near the bench).
So, thoughts on my plans? Am i an idiot, or going in the right direction?
