I have a problem with the outdoor sconces that is mounted outside my garage.
The current bulb flickers. I replaced it with two different kinds of bulbs and the problem still occurs. The flicker is going from brighter to dimmer, never completely on and off.
The bulbs I used were GE 60watt and 780 lumens and Ecosmart 60watt 800 lumens. Both do the same thing.
The label of the bulb base states "MAX 100 watts type B decorative medium based lamp"
Am I simply using the wrong bulbs or is this a wiring issue?
If I am using the wrong bulb, could someone link me to the correct one in 5000k temperature? I like the brighter white look compared to the soft white yellow hue.
Thank you!
Thank you!
