longlivepunk
So I got a couple of free 6" Record vises recently, both in non-working condition, one was missing a chunk from the static-jaw, the other was completely rusted and the jaw didn't move with the lead-screw. I assumed the second just needed new pins and I was right (they were both sheared completely off) but now I need to source some new pins, because the other has a bent pin as well. Any ideas on where to get good hardened steel dowel pins? I figured I'd try Acklands Grainger, Commercial Solutions, etc. but of course they're all closed today. I'll attach a few pictures for drooling over.
This is the first vise I got from a buddy whose shop broke a chunk off the static jaw making it unusable to them. Here it is torn down:
You can see the chunk missing in the last picture. So I got it welded by a guy at work who is an incredible welder, and before any comments arise about welding cast iron, we fly this guy accross the second largest country in the world as often as we can to do the welding at our machine-shop (which means he does lots of cast-iron repairs) so I'm not concerned about the quality of the weld. I then milled the face down and will have to drill and tap for one of the bolts and extract the other:
Then tilted the head of the mill and cleaned up the top a bit. It's not pretty, but it will be strong, and I got it to use, not to show off.
And this is the second vise, I got it from my work because the dynamic jaw didn't move with the lead-screw. I assumed the pins were sheared and I was right, so it'll be getting cleaned up and both will get new paint!
https://scontent-a-sea.**.fbcdn.net/hphotos-prn2/r270/1503822_10152112623484581_1625814380_n.jpg
