Hidy-hole in the Woods...
vonhef
Southern, Ok
Been awhile since my last project: http://www.garagejournal.com/forum/showthread.php?t=111827
But to make this story short, the Wife & I have moved from Western Oklahoma to Southern Oklahoma.... and after living 19 years in an area that had very few trees, we couldn't imagine not buying a place that wasn't in the middle of a heavily wooded area! The place we purchased is on 10 acres of oaks with the only clearing being what was performed during construction of the property.
The 30'x50' shop was constructed but never finished. We moved in the week of Thanksgiving holiday so the photos below are with all the stuff still unorganized.
One of the first things needed in this building is electricity. But the construction of this building had the C-Purlin open side welded toward the inside of the shop. So the first thing I did was to weld another C-purlin on the inside to allow mounting the breaker box and future inside wall.
My inside wall will only go 8 feet high, so I will need to repeat this all the way around the shop at the 0', 4', and 8' level. But with the electricians on their way... this was done first on one section to allow the mounting of the breaker box. I decided to hire an electrician to bring the electricity form the meter 300 feet away to the shop, then I will wire the inside myself.
Ditching through the trees:
Digging under the phone line to the house:
Service through the wall:
125 amp service box mounted:
Outside photo:
V
vonhef
Southern, Ok
While welding the inside C purlin today, I noticed that at the door opening there is a difference in relation to the outside purlin from the rest of the square tubing.
This is the 3" square tubing at a wall:
This the purlin as it meets the over head door:
I dug around the scrap pile and found a small piece of 3" square tubing that could be used to cut pieces long enough to wield onto the outside purlin.
Then allowed the inside purlins to be attached:
Hornman
Southwest DFW
I really like your shop, it looks a lot like mine, even down to the ceiling joists and insulation. Mine is 1200 sq ft, smaller than yours. Seeing your rollup door makes me jealous. I may have to borrow that idea. I'm just south of Fort Worth, not too far from you. One question: have you labeled all your tin pieces with your name and address so your neighbors can return them after the tornados? :bounce: We had one about a half mile from the house this spring. That gets your attention.
V
vonhef
Southern, Ok
You want a rollup door? What kind do you have on your building? Yes.... tornados can be scary, but If my neighbors find the tin after one hits.... I will thank them for cleaning up. :)
Limo57
North Georgia
Whewwwwwww...I am sure he would let you grind it off and fix it expertly for him since you are a (CERTIFIED WELDING INSPECTOR)
V
vonhef
Southern, Ok
As a certified welding inspector (American Welding Society), I hope you fired that welder and hired a professional to fix that stuff in the pictures. What a mess.
I know it's a mess... but that is the skill level I am at :)
All it needs to do is hold up 3/4" osb, and it will do that just fine.... no one will see it when its covered.
Thanks for the feedback :D
madoc1
spicewood, tx
well, your welds look better than mine! love the shop. also, didn't know there were trees in okla. maybe around pauls valley.:D
V
vonhef
Southern, Ok
Oklahoma is very diverse... east half of Oklahoma is wooded with even Pine Lumber industry in the south east. Western is mostly flat farm land. I have been told that Oklahoma has more miles of shoreline than any other state. It even has a Port of harbor
There is Sand Dunes:
http://www.travelok.com/listings/view.profile/id.4581?=KNC-Nat_Google12_LittleSaharaStatePark
Salt Plain:
http://www.stateparks.com/great_salt_plains.html
I am biased.... but I like Oklahoma. :)
V
vonhef
Southern, Ok
I want to finish at least one of the walls so I can start organizing some of the cabinets and stop working out of the cardboard boxes. Did make some progress to this goal in the last two days.
Used some scrap purlin to tie the inside walls to the outside... this eliminated the bounce of the inside purlins:
Then hung some of the 3/4" tongue & groove osb:
Then applied primer before calling it a day:
Hornman
Southwest DFW
I have regular 16 ft and 9 ft panel doors. The tracks on the 9 ft limit the height of my lift and the 16 ft in the open position kills the overhead room where I want to put my CNC router.
Enjoy your trees. They add quite a bit to the asthetics.
V
vonhef
Southern, Ok
Was driving around in Duncan, Ok. earlier this week and saw this shop behind a house... cant imagine why the Texaco sign was there, unless he just wanted it?
Oh... and I did get some paint on the wall today.
Next will be to paint a stripe down the wall, add a kick board and crown, and trim the window.
ripper70
Oregon Coast
HOLY SMOKES 3/4 osb on the walls? Thats almost a bomb shelter:bounce: Nice work man. keep the pics coming
V
vonhef
Southern, Ok
I know the 3/4" is thick for a wall, but since there are no vertical supports at the seams, I wanted tongue & groove so the seams would remain flush.... but I should be able to hang most anything on the wall now. ;)
V
vonhef
Southern, Ok
Well... I have finished the first wall with paint & trim. This allowed me to regain some sanity by moving stuff out of the boxes back into cabinets & bolt bins. I am happy with the look and am motivated to start on the next walls. After the walls are completed, work on lights and electric outlets can begin.
Instead of setting the welding table and work bench against the wall, I have them running parallel with each other and away from the wall so I can access from all sides. I will try this arrangement for awhile, but I think I will like this!
I also decided to do something about this loose insulation on the ceiling today:
When I investigated, it is obvious the builder didn't have the edge of the insulation under the sheet metal, so I had to take the screws out of the tin and then pull the insulation (from outside) under the tin and reinsert the screws.
Much better:
davo727
Did your roof trusses come from J & I MFG ? That company seems pretty good from their website. I wish they would open a store north of Houston like Conroe area or so.
V
vonhef
Southern, Ok
The shop building was already assembled when I purchased the property... So it is unknown to me who built the trusses.
rktolds
Tuttle,OK
Really nice place. Good to see another Oklahoman on here. I was fortunate to have a shop at my place when we moved here. What work or toys are going in the shop?
V
vonhef
Southern, Ok
Thank you :)
work & toys? The wife & I have good friends that we go jeeping/camping with often, so there is always something to do to the jeep. You really can't see it very we'll in the first picture ... But the off road camper is in the back ground. I also plan to build a heated & cooled office where among other things... I will reload ammunition.
V
vonhef
Southern, Ok
After weeks of terrible weather, finally turned nice this weekend and I made some progress!
I plan to build a 20' x 12' office/workspace in one corner that will be heated & cooled, have bathroom facilities, and will be used for reloading ammunition and other projects.
The standard vinyl backed insulation wouldn't be sufficient for the office area, so I added 1" styro board to the outside walls in that corner:
Then managed to hang the OSB down the south wall and part of the east wall:
Slow... but I'll get there. :D
V
vonhef
Southern, Ok
Had an installer remove the roll up door and install an insulated overhead today. I didn't like how when the wind would blow, the roll-up would rattle and let a lot of air through. I also plan to someday add a lift so wanted a jack-shaft operator installed.... and man am I impressed with the Liftmaster!
Very happy with the results:
Not really garage related... but I am also getting ready for mowing season :)
V
vonhef
Southern, Ok
Ran the first conduit & circuit today.... to the first light! The Liftmaster came with a wireless activated light, so I mounted it on the wall, ran the electricity for the garage opener, light & some extra plugs on the wall. Another cool feature is that the light will also activate via a motion sensor on the door opener switch.
V
vonhef
Southern, Ok
I have been welding the c-purlins on the north wall... so I can finish it and install an air compressor in the NW corner. So nothing really new to show.
I did purchase a new Lincoln welding hood that allows me to see much better.
While far from professional, my welding has improved a bit. :)
1/2 Cup
Member Emeritus
Shepparton. Victoria. Australia
How do you find the new welding helmet? My helmets are 30 years old and I am looking to purchase a new one as well. I do wear glasses to read with and find it a real pain when I am welding.
BTW your welds are looking much better, well done.:thumbup:
V
vonhef
Southern, Ok
This Lincoln Viking hood works really well. I like the really large viewing area. I like the adjustments inside the hood so they don't get bumped out of adjustment like my last one would. I also have a " cheater" lens ordered that will magnify the view.... So we'll see if that helps or not.
Oh... I wear glasses also and it is no problem with this hood. This hood uses both a battery & solar to supply voltage. I think you will like it.
Thank you, I am not a great welder... But it is getting easier. :)
V
vonhef
Southern, Ok
On another thread:http://www.garagejournal.com/forum/showthread.php?t=232702
I was looking at rebuilding an old Quincy air compressor until I found that it had spun a rod bearing and needed a crankshaft..... so back on the hunt for a quality air compressor. I like the old style of compression where they designed them to turn "Slow & Low" (slow rpm = low noise).
When I was telling my dad about the disappointment of the Quincy having a bad crankshaft... he told me about having an old air compressor that wasn't being used. I asked what it was, and he didn't even know.
Well turns out that it was the old air compressor from the gas station he owned when I was a kid! When he sold out he took it with him... and it has been sitting at my Brother-in-laws place for years not being used.
I loaded it up, took it to a car wash, and then unloaded in my shop:
Tank has a build date of 1957:
I took the head off and inspected the valves. they all tested good and sealed perfect... but the second stage discharge was pretty gummed up (top left) it should look like the one on the top right:
I didn't get a picture... but the cylinders still have crosshatch marks!:thumbup:
The centrifugal un-loader has an arm that rides against a "slinger" that moves back & forth when the fly wheel spins. I noticed it had a lot of wear and had nearly worn into the spring:
I cut some material and filled in the worn spot:
Put everything back together and test run.... and music to my ears!!!:D
It has a slight leak on the pressure safety valve and the tank petcock... so those are ordered. I also ordered some rubber islolator feet.
Next will be running 8 gauge 220 over to the spot it will reside.... but I am happy with it!
V
vonhef
Southern, Ok
I wanted to change the oil in the compressor but could not find 20w non-detergent oil, then discovered that iso68 hydraulic oil would work. After changing the oil, decided to disassemble, clean & paint:
While the paint was curing, took the 1000lbs isolators and cut all-thread, and then inserted into the legs:
After running the 220 circuit, the compressor is in its final place:
I still need to run air lines around the shop... but at least its available at the compressor! :)
