Scottishross
- Joined
- Apr 2, 2012
- Messages
- 621
It's coming together mate looks good
Coming along very nicely.
Coming together nicely! I, too, believe in the build it, not buy it, philosophy unless necessary. I like your resourcefulness in finding building supplies, especially when funds are low. I live in a major metropolitan area and can't find discards, overages or salvage items like a lot of European GJ'ers do and "dumpster diving" is frowned upon by the local gendarmerie here anyway.
Good to see the progress Mate.
Wish I lived closer and was able to pop over and give you an extra hand..... it helps having company and to get some bits up quicker.
Of course I would probably "find" you stuff you could use too.
Whilst you're at that stage you might want to conside adding in an outside socket, handy for all sorts from barbecues, to electric mowers to christmas lights!
I think you said you planned to cover those walls with plasterboard or something. If so is your sparky happy with horizontal runs? My recollection, which could be wrong, is that hidden cable runs in walls need to go vertically to the socket (or light switch) to make then easy for the muppet with a drill to find/avoid. I think horizontal cable runs need to be in surface conduit instead. Could be wrong but worth checking out.
From what I can find the rules state that the cable should only be run horizontally within 150mm of the top
OSG 7.3.2 Walls and partitions: "A cable concealed in a wall or partition must:
i be at least 50mm from the surface, or
ii have earthed armouring or an earthed metal sheath, or
iii be enclosed in an earthed steel conduit or trunking, or
iv be provided with mechanical protection sufficient to prevent penetration of the cable by nails, screws or the like (Note: the requirement to prevent penetration is difficult to meet), or
v be installed either horizontally within 150mm of the top of the wall or partition or vertically within 150mm of the angle formed by two walls, or run horizontally or vertically to an accessory or consumer unit (see Figure 7.2)."
If method 'v' is used in any wall or method 'i' is used in a part-metal wall then the circuit must be protected by a 30mA RCD.
Hopefully the bit in red means I'm OK. My cables run horizontally to the accessories (sockets) and that whole circuit will be protected by a 30amp RCD.
I looked through the whole thread now. A great project. You did the best possible out of your location. I'm looking forward to the next steps. I would love to build a garage on my own as you can do everything from the scratch right to your liking.
Good luck and have fun!
If you are getting out of the lock ups by the end of June does that mean you will have to move the floor finish up your work list?
