wmchurch
Moved into a 1959 concrete block house a few months ago. Existing service is 150A and it's a combination fuse breaker (main disconnect is fuse, with breakers for the circuits). I'm not exactly sure who makes the box, and I can't find breakers to fit it to save my life. No room left and frankly I'm not all jazzed about the main fuse disconnect (this is all in one box).
So, I've replaced a panel before in my previous house, but I did it before we were living in it so I just yanked the old panel out and put the new panel in it's place.
My plan here is to put the new panel beside the old panel, backfeed a 50AMP circuit to the new panel and start moving the breakers over. I will end up using a new meter can and riser (aerial cables), but I want to put it in the same location as the previous so there will be some downtime.
So, I know that when back feed, just like adding a sub panel, I will not bond the neutral and ground of the new panel. I also believe I need a 50AMP breaker in both the new panel and the old panel.
I plan on just running lights and plugs (back feed) on the new panel. The actual load will be light (every light in the house is LED and the few accessories we have are pretty low, computer, TVs, etc…)
Once the new panel is on the service, I'll move the heaver loads (A/C, Stove, Dryer, etc.)
With all that being said. I'm looking for a recommendation for a panel. I'm mounting it in the garage, about 2 feet from the existing panel, but closer to all of the loads (should make it simple to route the existing wires, no need for junction boxes). I want a lot of space (elbow room, interior space in the box).
We're using the 2007 NFPA 70 National Electrical Code (Saint Petersburg, Fl). I happen to have a copy of CodeCheck and I think that will help a bit.
I'm leaning towards the Siemens panels like this one:
http://www.amazon.com/dp/B005GLDFHI/?tag=atomicindus08-20
I like all the ground and neutral bars and like the copper bus.
Siemens has some interesting breakers like this one:
http://w3.usa.siemens.com/powerdist...t-catalog/Documents/sf-11-sect-01-044-046.pdf
It's a whole house surge protector (required) and 2 usable independent 20A breakers. Essentially this uses up only 2 spaces, but gives 2 usable 20A circuits. Previous solutions I've used "wastes" two circuit spaces for the surge protector.
I also thought this was kind of cool for your A/C unit, combo breaker:
http://www.amazon.com/dp/B000VYKYR4/?tag=atomicindus08-20
I'm thinking things like that will help keep some of the clutter down in the box and make it a bit nicer when installing everything.
Thoughts? Any experience with these panels/breakers?
