Anyone know what model drill press this is?
stephen4785
Benbrook, TX
Iv searched online and looks like a Delta/Rockwell 17-600 but it's different.
It has a 3ph 1hp motor and I cant figure out what is on the side where the spindle return spring usually is.
Thanks
stephen4785
Benbrook, TX
It was on ebay for $250 and it's local. I havent seen it so Im a little worried. Once I get it home Im going to take it apart, sandblast everything, repaint it, and get a variable frequency drive to run it since I only have single phase in my shop. It'll beat the heck out of table top hf one I have.
If you haven't' bought it already, and the $$ is right, stop quibbling and go get it...
You can ask about details later!
schor
Ajax, Ontario
Might be a buffalo 18. but the head casting doesn't look quite like an 18., Maybe an earlier model?
Scratch that buffalo idea. I am not sure what it is.
OK sounds like you are nearly there.
DON'T "sand blast everything"...
Rough castings, fine, (But not my preference. look into using Electrolysis. it will generally take both rust and paint off..)
Machined surfaces... Nope.
stephen4785
Benbrook, TX
By sand blast everything I mean to remove the layer or paint someone sprayed it with. Iv seen electrolysis stuff before. I'll have to try it out. Im not going to sand blast the support tube, table top, top cover, spindle. Just the base, bottom of the table, and outside of the main body. I am about to rent a soda blaster for my caddy project so I might wait and use it.
zkling
BMcC is correct, it is a late model delta 17", production table, MT2 female taper spindle, could go either way on the pulley set, but probably slow speed. It is a stout machine ~350+lbs. :thumbup:
The thing on the side is the return spring assembly, and Delta's new fangled depth indicator. The various holes are for optional attachments like power down feed and foot feed. I'm digging the orange motor.
Hmmm 50 YO DP, and "new fangled" :headscrat
:willy_nil
zkling
:willy_nil
Considering that drill press had already been around for ~25 years I guess they felt it needed an upgrade. :dunno: That is dang near digital compared to the one on my 1939 or 40 edition 17". :lol:
stephen4785
Benbrook, TX
I got the drill press home and started stripping it down with some paint stripper. The drill press tag says 17-600 1335448 which is a 1963 model according to Vmwk.
I also stripped the paint covering the motor tag and found out that's its a 3/4hp and not a 1hp like the ebay description says. Im a little pissed about the hp difference. Is 3/4 vs 1hp really that big of a difference?
Thanks
what the motor tag should look like http://www.publicsurplus.com/sms/do...uction Pics 036.JPG?auc=1054325&docid=8926892
WWIIjeep
Arizona
No, the difference will be negligible in normal use.
That model came standard with a 1/2 HP motor, so 3/4 HP is plenty.
The optional 3/4 HP and 1 HP motors were recommended when the drill press was equipped with power feed (which yours doesn't have), or for use in a production environment.
I doubt you will have an issue.
Most common shop/home DP's come with 1/3 or 1/2 HP motors I put a 3/4 HP on my old DP only because I did a lot of hole sawing in steel and that bogged it down.
Keep in mind the larger you drill the slower you turn the bit, so you also get the gear down factor in your favor.
here are the MFG recommendations for my new (to me) Canedy-Otto 18" DP (slightly larger than your Delta Rockwell. 3/4 HP should be fine...
383 240z
Findley Twp. Allegheny Co.
I have the same drill press but with a damaged table. I liked the HF table in the link. In fact I almost bought the HF press because of the table. Now im off to find the part number for it and order one up if its reasonable. Keith
scw1991
it's a 17" Delta model 17-600 from around mid 60's. I owned one and fully restored it. Beautiful machine.
stephen4785
Benbrook, TX
You need part 15b from item #39955 table w/ scale
page 17 http://manuals.harborfreight.com/manuals/39000-39999/39955.pdf
I have an email off to the hf parts department. When I get a qoute from them I'll let you know how much it costs.
stephen4785
Benbrook, TX
I stripped some of the paint and removed a little rust. Here's some better pics.
I think the table is almost a total loss. Why on earth do people do this ****?
I ordered a vfd. Do I still need this box and if so whats it function other than a reset switch?
scw1991
I retrofitted my Delta DP 17-600 about 5 years ago with the Harbor Freight slotted table. The OEM 11" Square table was pretty useless.
WWIIjeep
Arizona
That's a magnetic motor starter with overload relay. The on-off pushbutton station on the front of the head casting controls it.
Your VFD probably comes with on-off control, but maybe not with overload protection.
383 240z
I called HF today, they have the table in stock. It is $102.33 freight is $6.99 to my door. Item number is 39955 part number 15B. Have to see if I have any spare money at the end of the month. Keith
yaidunno
WI
Definitely keep the box to mount the VFD in. I just finished up the same setup on my Delta 17 and couldn't be happier.
stephen4785
Benbrook, TX
I dig the box itself. It's cool as hell. I just didnt know if I had to keep the guts themselves. I'd like to have reverse for tapping stuff and removing boken bolts with left hand drill bits. Will a vfd do it all or do I need to use a barel switch or something? This is the vfd I ordered. http://dealerselectric.com/item.asp?cID=0&PID=4703
I do want to remove the box mounted to the front that houses the on/off switch. I'd love to find the original switch plate but I might have to settle with something else.
454ragtop
Carver, MA
You can use the original switch to control the VFD, but as mentioned above, a 1/4 HP VFD isn't going to cut it.
yaidunno
WI
I posted the wrong link http://dealerselectric.com/item.asp?cID=0&PID=4705
I couldnt find a good deal on a 3/4hp so I upped to a 1hp.
Looks like that will do the job. As for the VFD doing it all, it will, but it will be much eaiser to have external switches/pots for the forward/reverse and variable speed. The VFD will be programed by you, which is real easy to setup. On my Teco there are approx. 30 different parameters to control. Its very versatile.
Here's how i have mine setup. The "rod" coming out is actually my potentiometer, i just haven't found a knob for it yet. My box didnt have a front cover, so i had to make one. Drum switch in the back for forward/n/reverse. At first i thought the drum switch was going to be a pain to reach for taping, but with the foot feed it works out well.
stephen4785
Benbrook, TX
Looks like a geat setup. Did you restor that press and do you have any other pictures of it?
yaidunno
WI
