Parker vise question...
drivesitfar
I just paid $75 for a similar designed Rock Island vise and the Parkers usually get a little more for them. i'd buy it since I don't currently own any Parkers if the other side looks just as nice. i'm guessing a 3.5 or 4 inch jaw and maybe early 1900 vise with the bolt coming out of the bottom of it.
as always when looking at old vises and tools check for cracks and old welds that might be painted over that will affect value and use. good luck
bl00
Chantilly, Virginia
I'd pass. The collar looks like a replacement, the support for the front slide is missing, it doesn't appear to have a notches to lock-in the base to keep it from swiveling, and it requires ample room under your bench to manipulate the handle to lock/unlock the swivel.
drivesitfar
B100: so these old Parkers had the lips under their slides on the static slides that you noticed missing? it would show up as a broken piece on closer inspection usually. correct?
I thought the original front piece was not as thick as maybe an original but aren't these little ones easily found for $7.50 or thereabouts?
the swivel nut under it tells me yes it is a bit harder to use if you want it to actually swivel, but isn't this vise early 1900 or late 1800's?
i'm definitely not a fan of broken off cast so I might have seen that on closer inspection, but the other issues are fixable are then not and not for much money considering the age of the vise?
T
taumac
Brooksville, Fl
Sorry guys not too many pictures but guy eyeballing he after I went outside to grab my phone to take pics.... I know where its at but I did get this one for $17 uploadfromtaptalk1391456456343.jpguploadfromtaptalk1391456469888.jpguploadfromtaptalk1391456483804.jpguploadfromtaptalk1391456499537.jpg
I question ID help I snap pics before I tried to clean some green paint but as removing paint with water and tooth brush it started to put paint label
Have a good one, Gerard
The 5 Stitches Garage part 1 http://www.garagejournal.com/forum/showthread.php?t=142100
The 5 Stitches Garage part2 http://www.garagejournal.com/forum/showthread.php?t=211899
bluebolt
Benton LA
That first Parker is in pretty poor shape, PASS!
The second one looks interesting. I can tell it ends in "ER", the only vises I know of that do that are Parker and Sawyer. What size is the jaw width? How far does it open? Weight? Does that read 32 1/2 in raised letters on one side. Don't recall a vise with those oval recesses in the slide before. We need more pics!
bluebolt
Benton LA
Yea I just figured out myself it appears to end in "THER".
For opening width measure it with the slide flash with the back of the main body, thats the safe fully supported opening distance. Look at it with different lights and different angles, you might make out more letters.
It's a cool little vise!
bluebolt
Benton LA
Maybe that says Luther and the L goes over the u? Kinda looks like it.
T
taumac
Brooksville, Fl
I keep looking at it on phone under high zoom and looks to be R or P then think "I" Pither Rither idk
Second lol again it does look like a u so maybe is cutter but thought it looks like ther vs tter idk its cool little vise no matter. Think might pass on Parker for moment but I dont see many good vises around in my parts and didn't know if worth it.
bluebolt
Benton LA
Yep it's a Luther from Milwaukee Wisconsin they made grinders and vises! Found this picture on Worthpoint.
T
taumac
Brooksville, Fl
LOL that's too funny I just found this through Bing.... Luther L145
Sold for 23.50 with 12.00 shipping on March 7 2013
bl00
Chantilly, Virginia
It appears that the whole support is gone (circled area below). Is there a source for the front collars? I remember someone casting a few, but don't recall seeing any otherwise. Yes, I think it is an old one, but can't find the model number listed anywhere to narrow it down.
