JMartel
Seattle, WA
Cleaned it. I can finally see the floor not covered in 2" of sawdust, and there's empty space on my bench.
Syberia
Perris, CA
Replaced the wife's valve cover gasket. The car no longer smells like exhaust and burning oil every time it's sitting still. She has such bad allergies she swears she could never smell it.
ewils35
Metro Detroit Area
I did the same thing over the summer. What kind of a car she have
Sent from my DROID RAZR HD using Tapatalk
Lippyp
Shropshire, UK
Test fitted my roof light bar on the blazer and then took it apart, just need to enlarge the holes in the front where I'm sticking four amber leds as marker lights. I had to go out this afternoon and buy a decent 12mm drill as mine was blunt, so I treated myself to a nice set of titanium coated ones, 1 to 10mm in 0.5mm increments and a seperate 11 and 12 mm.
I also spent some quality time with one of my boys whilst his twin was out at the supermarket with his mum. We spent half an hour or so going through all my drill bits that were just chucked in one big tin box and seprated them out, the wood spade bits are now in a little wodden box that once held Turkish delight that was the perfect size, all cleaned and oiled by my able assistant, masonry bits in a little metal box that once held a cheap 1/4" drive socket set, and the HSS ones in a bigger metal box that once held a 1/2" drive socket set. Still need to find a suitable box for some other wood bits. Then we had a tidy up, wiped the steel top of the bench down with some WD40, filled all the bird feeders from around the garden and came in for a warm up and some lunch.
RumT
PDR Kalifornia
Welded on new leaf spring perches for a spring over conversion on my Xterra.
Cut off the stock shock ans sway bar mounts.
stitan06
<a href="http://s1268.photobucket.com/user/stitan06/media/2014-02-15092336_zpsc8279aa3.jpg.html" target="_blank"><img src="http://i1268.photobucket.com/albums/jj561/stitan06/2014-02-15092336_zpsc8279aa3.jpg" border="0" alt=" photo 2014-02-15092336_zpsc8279aa3.jpg"/></a>
made some paracord stuff out usa made 550 paracord
LS6 Tommy
Northern NJ
Retrofitted the headlights from a Snapper 1028 snow blower to my 8260. The pics are misleading. The lights are a lot brighter than they look. I also used some 1/8" haircell finish black ABS to extend the sides of the chute 3". I hoped to reduce the amount of snow that "leaks" out the sides & drifts back in your face. It worked pretty well when I ran it tonight.
They're phone pics so they aren't too good, but you get the idea...
Tommy
BellyUpFish
Alabama
R
Finished my small welding/restoration table. Thanks to all the GJ gang for some great ideas
I like that table.. There's one here in the plant if like to replicate that looks very similar to yours.
You mind me asking how much you've got ******* in that?
I need to build one.
coma13
Cleaned up this vise I just picked up.
Cut out the top for my welding table to be from a big piece of 1/2" plate.
56vette461
I like that table.. There's one here in the plant if like to replicate that looks very similar to yours. You mind me asking how much you've got ******* in that? I need to build one.
Bellyupfish Thanks, It's great for a sit down welding work table.
I picked all the metal up at our local steel supply dealer's scrap pile. I look there before I go to the remnant stacks. I think the legs, cross braces and the top was about $45 bucks. I always go for the odd lengths and rejected pieces off their plasma cutting table to keep the cost down. I had to square up the top because it was part of a weird piece. I would guess the retail price on the same standard length pieces and top would be about $100 - $125. Primer and paint are rattle can Rust O, and what I always keep around for my tools and equipment. The wheels are HF at about $4.50 each with discount coupon
radrush
Atlanta, GA
Got bored and saw some PVC laying around so I threw together a little target stand. Looks like I'm shooting a little low and left...hmmm.
Outlander
Quebec, Canada
Helped the neighbor interpret results from scanning his Dodge pickup. Turns out he got an exhaust from his scrap yard buddy, no catalytic converter. Guess that's why it did not complete some tests. Result - no help with his truck, but I'll burn him a CD with software that came with my code reader (same model).
bobcatdan
Kaukauna,WI
While changing oil on my F150, noticed I had a broken front spring. Got some new loaded shocks and slapped them. Pretty damn easy to change and for a 9 year old truck from Wisconsin, everything came apart nicely.
Jimmy_B
Got rid of the cement blocks I had piled in front of the door as steps. This looks much nicer and will work a little better for my dogs once I install a pet door here.
Sent from my mind using ESP.
Lippyp
Shropshire, UK
Slapped four coats of satin black rattle can paint on my Blazer roof light bar, then I mucked out her car and gave it a good wash and also washed the winters green slime off my project pickup truck. Heading back out there now for a bit of tidying.
Ragged Earl
Finally had enough people over, and nice enough weather, to try out "The Beer Hole".
It's a 4' roll up.
shopboy13
NY
Spent 4 hours changing the oil and fixing the pull starter on the Honda recon. The 3 8mm bolts that hold the starter take all the extensions I own to reach. The oil change was easy of course. The bolt was loose in the center of the starter causing it to make a pinging sound at mid rpms
41ratrod
Springfield Mo.
changed the oil and checked the brakes on the Honda Civic all so cleaned
the head lights. Got to get it inspected Monday and renew the license plates.
Then went out to the shop and did some scrapping . Now I got about 15lbs. so aluminum and 5lbs. of small peace of steel.
I used the oil from the Honda to treat the trailer wood ,I try to do this each fall but didn't get to it last year.
fourhour
Put a stile on the make-shift corner cabinet I recently built and then added a foot wide shelf around the remainder of the perimeter using an old bi-fold door taking up space in my cellar.
Carguy99
Warrenville IL
With 6 -8 inches due tomorrow I got the snow blower running again. I just rebuilt the carb this fall. last snow it was running until I ran out of gas. gassed it up and it would only run with the choke on full. pulled it apart and cleaned it out … runs good again. not bad for a 17 year old 2 stroke. I guess it was done working for the season.
JimVonBaden
Northern Virginia
In my work sheds I did complete service on 12 MSF motorcycles, plus changed 11 clutch/brake levers, 3 tires, two clutch cables and various minor fixes. Busy 8 hours.
Jagmandave
Overland Park, Ks.
Spent most of Saturday working on a classic Mini Cooper, we installed an entire new exhaust system from the head to the rear bumper, which required removing the intake man and carb too.
Once that was done I rewired his fog and driving lights, I had drawn him a schematic last time I was over but all he seemed to do was let the smoke out of his wires and mew switches. I started over again and when it was done....let there be lights!
New exhaust out of the boxes....
Exhaust in and done...sounds great too!
Time to get started on the lights.....
Let there be lights!
MillerMav
Got about 65% done with my new landing. Still need to build new stairs and stain but the uprights, compressor location and cable rails are fitted just like I wanted! Stairs should come in the next few weeks but staining and paint will have to wait until April-ish
Rarely am I not posting from my phone....
