Thought I'd bring this up again. Earlier in this thread I mentioned I was ordering the PI split beam torque wrenches in 3/8 and 1/2 drive flex head from Tooltopia. I ordered last friday evening late. Today, tuesday, I arrive home to find them on the back porch. Thats good service for free shipping!
Anyhow, the 3/8 drive has a round metal hand grip, apparently PI has yet to switch it to the ergo grip. I found a thing or two odd about it, the end of the handle is open, no cap, nothing. It does have a cheap plastic plug shoved way up inside of it, but nothing on the very end (see the pic). The dial is not very easy to read either, no contrast, just numbers and lines stamped into a metal dial, you align with a small notch in the window.
The 1/2 drive came with the ergo handle. They also improved the dial, it is white with black lettering, and a black line etched on the "glass" window. But for some reason, they put a heavy black arrow on one end of the black line, and the arrow covers up the numbers and marks and makes exact alignment difficult, you really have to pay attention to get it set right.
I'm not crazy about ergo handles, and I had questions about the open handle (was an end cap missing?) and the knob on the 1/2 drive seemed "ratchety" to me. I called PI and talked with a rep who told me the open end of the handle on the 3/8 drive was normal, and while talking about the not so smooth operation of the knob on the 1/2 drive I sat and played with it and found it to work fine. Just needed some fiddling with it. I mentioned the ergo handle and they said they had good and bad comments about it. I mentioned that it looked cheaper to make, they didn't have to form the square metal tube into a round shape on the handle end, just slip the ergo grip over the square tube and install a couple of screws. The rep asked me if I had ever worked there, apparently my thinking was something like their engineers. The rep also wanted to know how much I had paid Tooltopia, $155 for the 1/2 drive, and $116 for the 3/8 drive, including shipping. He was astounded, that "was cheap".
I also asked about the 4% accuracy from 20% to 100% of scale and got the same answer I got from the Norbar - Australia tech I talked with (see my last post in
this thread.)
Anyhow, below are some pics of the two new Precision Instruments split beam torque wrenches. The last pic is a group photo of all of my torque wrenches (suddenly I realize how much I have gone overboard on the torque wrench collection)
Front and center, Seekonk 1/4 drive 30 to 150 in/lb micrometer type
Just behind the Seekonk is a Sturtevant-Richmont (SR) CCM150I interchangeable head micrometer type (with no head) 30 to 150 in/lb
Front right is a SR CCM150F interchangeable head micrometer type with a 1/2 drive head, 30 to 150 ft/lbs
Front and left is a SR CCM750I interchangeable head micrometer type with a 3/8 drive head, 150 to 750 in/lbs.
Second row left side, is a Snap-On dial type "Torque-O-Meter" 1/2 drive, 0 to 250 ft/lbs
Second row right side is a Snap-On dial type "Torque-O-Meter" 3/4 drive, 0 to 600 ft/lbs with no extension handle
Middle, third back is a Gedore 4507, German made 5 to 40 ft/lb with a 1/2" female square drive, micrometer type. The male push thru square drive plug is missing, but I am ordering them 1/2 to 1/2 and 1/2 to 3/8
Left side, third back is the new Precision Instruments 1/2 drive flex head split beam C3FR250F, 40 to 250 ft/lbs
Just behind the Snap-On and Gedore... is the new PI 3/8 drive flex head split beam C2FR100F, 20 to 100 ft/lbs
To the far right, past the PI 3/8 drive, sitting on top of the reddish box is a Utica interchangable head 10 to 150 in/lb micrometer type with both 1/4 and 3/8 ratchet heads. I have seven of the torque wrenches but only one of each of the heads.
Red box to the left is a early '70's vintage Craftsman 3/8 drive beam type, 0 to 50 ft/lbs
Blue box is a early '70's vintage Craftsman 1/2 drive beam type, 0 to 150 ft/lbs
Far right in the plastic package is a '90's vintage Craftsman 1/2 drive beam type, 0 to 150 ft/lbs
Also far right is a '90's vintage Craftsman 3/8 drive beam type, 0 to 50 ft/lbs
To the left, the electronic meter in the package is a
Craftsman 44599 electronic torque measuring system, 0 to 150 ft/lbs
Last but certainly not least, is a English made
System Norbar 3/4 drive (push thru square drive plug) ratchet, clicker type, 370 to 1100 ft/lbs with its metal case and extension handle. Over five feet long and has a nearly two foot extension handle with it
Edit: sorry 'bout the pics not being here. I had uploaded them, apparently they chose to run off with other tool pics and not hang around.
Charles
