The Harbor Freight PASS/FAIL Thread...
Provincial
Near Salem, OR
I will not own a blow gun that isn't made of metal. But then I use 175 psi of air pressure. Don't think I'm a HF snob, because I own several HF blow guns!
cheechi
Triad, NC
I honestly didn't even consider a blow gun to have a limit.
Back in school one of our safety rules in the shop was blow guns all had locked-out regulators on them so they blew 30 psi. I know you can get the safety blow ends now but they weren't as common before.
There was one of those safety videos we had to watch, according to it as little as 60 psi is enough to break skin. Something that always stuck with me if i'm blowing off dirt & dust I will turn it down every time.
SteevoLS
I much prefer metal guns myself, but as far as the fitting (in the plastic gun) t is just formed in. Put a little JB Weld on it and it will be fine.
norry
Out of my mind... Be back soon!
IMHO any air tool not designed for 'normal' full line pressure should be marked to that effect, whether it's HF or Snappy.
And yeah, when I read about tools bursting into flames or flying apart at high speed, I do wonder how HF manages to steer clear of the lawyers sometimes!
NoSloCoupes
IL
How about sending that email my way? All stores are about 1 hour each way from me. Bought a textured paint 7 drawer end cabinet. Opened it up and its got a huge scratch, plus the drawers don't even match my box, upper chest and end cabinet i bought a couple years ago. This thing must be really old??
I'm sending you a PM with the email address for a person who's helped me out at HF everytime I've contacted them.
Wes
djjlm
Welcome to GJ...
What was it about the flux core wire you didn't like?
It is the cheapest flux core wire I have been able to locate, especially with a 25% off coupon. I have run at least three 10lb. rolls total without problems in a Hobart Handler 190 welder. The only complaint I have is that the slag is hard to chip off, but not unreasonable.
I find it didn't run as well as lincoln wire from home depot, and for the same price i could get the lincoln wire, maybe thats just me
Danglerb
SoCal
I like about 90+ psi to take off paint and I wear gloves.
Hint, stuff in a shop isn't safe to play with, everything needs directions followed and safety practices, not making tools useless attempting to idiot proof them.
cheechi
Triad, NC
Yeah this was high school auto shop. I still stick a regulator before the blow gun in my own garage out of habit, sometimes I put it wide open but often if i'm just cleaning stuff up I start low and go up to whats needed. I think I have one with a safety end but I never use it.
Jasonfi
Anyone own the 90 amp flux wire welder from HF? If so do you think it's a decent welder for the average do it yourselfer? I see it's on sale for 79.99 March 7-9 and I was thinking about picking one up.
Sent from my SCH-I545 using Tapatalk
Mohawk Dave
SoCal
Put it this way. I kept one on the property (along with my big Miller), just to weld up stuff like the front security gate. B/C I could carry it out there...vs the big Miller.
I used it for repairs, but not for fab or anything. I recently found a Lincoln WeldPak for $150 on CL, bought it and sold the HF 90. The Lincoln is 10x better.
So...it kinda depends what you want it for.
FOCUS.FREAK
Burr Ridge, IL
#68424
Tested it yesterday and today on both lugsnuts. One was a 22mm on a small mini school bus. Took that off no problem. Next up was the 11r22s. Those are some big fu#kers. I had it on for maybe a second and it broke it loose like butter. 33mm socket for that test
Sent from my SPH-L720 using Tapatalk
BrownEnterprises
West Texas
Bought a "Badland Winch", 9000lb capacity. After getting the main winch assembly installed..found out two cables were swapped. Swapped them and found the trigger wire was on the wrong power source. Swapped that. Then found the switch operated backwards. Swapped that and it worked. Two days of figuring this thing out. It works now but have not yet tested it's abilities. So far it's a fail in getting out this far with so many things wrong.
mikerod
I had the plug on the remote fail on mine after about 6 months of infrequent use. I replaced it with a 4 pin trailer plug. Just recently the free spool lever got stuck and will not turn, I had to power out to use it.
The paint and the insulation on the wires have sun faded badly, all decals have started pealing. Everything chrome finished on it has started rusting in spots.
oldtools
Snap On website said not to use non-vented blow gun above 30 psi.
fitz11
Fox Valley, WI
When did you buy it? The stores haven't had the textured finish in probably 2 years. I doubt anyone at HF would do anything about it.
MackMan
Lexington, NC
Fail on the metal blow gun as well, this one at 50 psi
It's the blowgun in this set
http://www.harborfreight.com/17-piece-air-tool-accessory-kit-68236.html
Item# 68236
Was using it just to bleed off some residual pressure. Had around 50-55psi left in the line, plugged it in, and it blew the valve out (bent the "trigger" back). Lucky for me at the low pressure it just fell out rather than shooting off into the distance. The threads where the valve screws into the body did not appear to be damaged, however I could push the valve back in by hand. Went straight to the trash.
67carl
California
Drill Master Auger bit set #68166 - Fail.
The 2nd largest bit drilled one hole, then after that won't cut into the wood unless I rock it back and forth. Even then it's a tough go to get it to drill in. Another bit is crooked and wobbles when spinning. A few of the smaller bits have been working great after repeat use.
67carl
California
Chicago Electric 1/2" variable speed reversible heavy duty D handle drill. 9 amps. Item #69453. I believe this replaces the orange one but not sure. Pass.
This thing is a beast and can twist your arm off if the bit gets stuck. I've only been using it for a short time but it has been awesome (this is my first big drill so maybe easily impressed). Drilled several 1" holes through a 2x8 sistered to a 4x8 and it went through like butter.
With a 25% off coupon I paid about $30 for it. How can you beat that?!
NoSloCoupes
IL
Bought it Saturday. It was a very old one thats been sitting tucked away apparently,lol. The drawer pulls were in the middle and drawer fronts were flat.
There is 2 versions on the website, one is high gloss #69399 and the other just says red #68785. I figured the latter was the textured/dull. I took it back to another store and all three #68785's they had were gloss. Guess i thought wrong and no textured are even sold.
btlegacy
NC
Item#98265 - 7In Bridge Tile Saw
Got it for $140.99 with 25% off coupon
Picked up a nice Ridgid Blade at Home Depot to use with it
Used T-square to calibrate all the angle guides and cut alot of tile with no issue.
It worked very well and all the tile was within a hundredth of an inch edge to edge
The pan below unbolts with 4 knobs so that you can clean it easily
Overall, very happy with it
NoSloCoupes
IL
This torque adapter has good reviews so i bought one... http://www.harborfreight.com/digital-torue-adapter-68283.html
I was interested in seeing if my 15+ year old craftsman torque wrench could do for a calibration...and the harbor freight 1/4" and 3/8" i bought. Well, it worked out of the box but after a few attempts at higher readings(anything over 40 ft.lb.) it kept shutting off and eventually wouldn't power up. I returned it today for another...same damn thing!
Harrison2
Bay area and UK
possibly cheap batteries?
IONH
Central Massachusetts
The reviews talk about the case possibly turning the unit on while inside. Perhaps the units came with batteries and they were mostly drained before you got it.
NoSloCoupes
IL
They have a plastic strip that prevents the battery drain that has to be pulled out before use. I tried turning both on before removing the strip to see if it was doing its intended purpose...neither came on. I'd imagine bad solder joint somewhere but I'll check battery voltage later.
Aquaticbob
Seattle
http://www.harborfreight.com/6-in-cut-off-saw-61204.html
6" cut off saw Item#:61204 [highlight]FAIL[/highlight]
This thing worked for 3 cuts and that was that. I was using it on 2"x36"x1/8" flat bar that I was cutting down for welding practice. I used a couple different discs, and tried it on another bar just to make sure it wasn't some random hard spot in the metal, or a bad disc. I also replaced the carbon brushes that were just fine to make sure that wasn't it either. I'm not really sure what went wrong with the little saw but boy was it working like a charm for those 3 cuts! I was really impressed with it, then I brought it down and got halfway through a cut before it just stopped cutting all together. After that there was no more cutting no matter what. I returned it to the store and made some $$ back because they gave me back the money for the retail price, not the 25% off I got it for. I decided I would at least give it a shot because it was only $30. I'm going to end up getting a better saw seeing as to get stock cut down to the size I want within a few buys the cut fees would add up to the price of a decent saw
tcianci
Walpole, Ma
HF Multi function tool finally quit but a resounding PASS!
I bought the base HF multi function cut off tool when they first came out with it. I have been using it nearly every day for years. The first time it quit was because of a bad crimp on one of the wires. Easy fix. The 2nd time it quit, ( a few years later) the braid to one of the brushes fell off. I knew that the tool came with spare brushes, but I couldn't find mine so I jury rigged it to supply current to the brush through the spring that tensions it. A couple of days ago I went to turn it on and nothing! I kinda got a smile on my face because I had a 25% coupon for HF and I have been wanting the variable speed version of that tool ever since they introduced it. I bought the new unit but I'm still going to take the old one apart and see If I can get one more rodeo out of it.
We all know about the general reputation of HF stuff but this tool has been a real workhorse and well worth the 20 to 30 bucks I paid for it years ago!
__________________
People are doing either what they THINK is right or what they KNOW is wrong.
Ok, Time for an update. I have been using the HF variable speed multifunction tool for a few months now and this thing kicks ***! So much quieter than the original fixed speed unit, but that may be partially due to the fact that I haven't had the need to run the thing full tilt. I have found that blades (even the HF crapola blades) last much longer at lower speeds. I think a lot of blade failure can be attributed to excessive heat. So, I'm getting quieter operation, and longer blade life. I'm a happy camper.
pauls_workshop
Indiana, USA - Underappreciated Place to Live!
It is a good one, but even better is they nearly identical Menard's variable speed multifunction tool which comes with many many more accessories than the HF one and at lower cost. The previous version of the Performax at Menards looked *identical* to the then HF version, with a different label. Same supplier for sure. - Paul
Aquaticbob
Seattle
Rakoprtr
Huntsville tx
Anyone have a review (or tell me what page it's on)for the rad pressure tester I searched but couldn't find it surely someone tried it
cheechi
Triad, NC
That's the big downfall of the fixed speed one. It goes at 21k and the variable speed one tops out at 20k, both of these numbers on paper of course. But yeah, for the difference in price the variable is a no brainer.
Lhorn
If you guys want to have some fun, join us over at the new Sears Pass/Fail thread! It is inspired by this here HF one, but so far has a much higher percentage of fails than we have over here! - Paul
Nice plug for your own thread. Reviewing Sears for a pair of Wolverine boots. Nice!
I one got bought a rice cooker that broke so Walmart ***** too. Lol
67carl
California
I can't help you with the tool itself, just a better way to search for it here. For some reason you'll get better results if you do a Google search with a description like "garage journal harbor freight pass/fail item #***". *** being the part/tool number.
If you don't get something then its likely not been reviewed or someone didn't include a very good description.
ndr1968
Oklahoma
Here's a new item that showed up in the march flyer today. I wonder how useful it really is ?
Adjustable Steel Welding Table
Regular price - $149.99
on sale - $59.99
http://www.harborfreight.com/adjustable-steel-welding-table-61369.html
Whoa! Damn! I just bought that table from Cyber Weld a while back and paid full monte! Doh!
I do small (tiny, really) projects mostly and it has worked pretty good for me. If you weld in one spot over and over though I have notied some slight warpage in that area. Weld spatter grinds off easily. I use mine all the time and would probably buy another at full price it it were the only option. 350 pound capacity? No Way! I'm 170 and would only climp on this thing with extreme caution!
ndr1968
Oklahoma
on sale - $59.99
I did just notice that the HF version isn't adjustable for height. Strong Hand adjusts 26-32 inches. Also, the Strong Hand has another "fence" running along the short end that used with the length wise one could be used as a square corner set jig. Still, I'm impressed with the price. A little work and some stock, maybe the height could be made adjustable?
Oh yeah! I forgot! The Strong hand comes with "free" two mini magnets and a spring loaded "F" clamp that's pretty handy sometimes.
Here's the Strong Hand version at Cyber Weld: http://store.cyberweld.com/webehabe300.html
