I read the whole thread, awesome stuff. I'm at the tail end of restoring an old baldor grinder, and I think you can answer some questions that have been plaguing me, if you don't mind:
1) Is there any reason specifically to paint the cast iron rather than powdercoat it?
2) Did you do anything to the stator other than clean and grease it?
3) What was the COO of the new bearings you put in it? Did it feel bad to replace US made bearings with imports even though the tool needed it?
4) What did you do to repair the cloth covered motor wires?
5) What gauge power cord was the new on? 12 or 14? Would 16 work?
6) How did you make the motor label? The Baldor has a similar label riveted to the center band, much like the motor on your press. I think it's aluminum? It's trashed and I am not sure how to make a new one without sending a 2x3.5 piece of stock to a screen printer (making the artwork for the label is easy, already have it. I have a vinyl plotter as well).
I appreciate any advice you can provide. Nice drill press, I'm jealous.
Actually I'm really more jealous of your lathe.
I just papered up to the edge as best I could. Then took a light run over it to get to a fresh layer of plastic of brighten it up.
), DH better stay on the straight and narrow!
