FS: RED Extension cords, 12/3, 14/3
mrb
What applications have you used 10 gauge for?
long length to minimize voltage drop. For example I recently did a temp setup to power an air compressor that drew around 15amps at 240v. It was about 140' of cable so I used 10/3.
I havent had to, but I would also use 10/3 for long runs if welding (assuming mig welder running at 120v)
Bull
do you want me to set a 50' 12/3 aside for a couple weeks?
That would be great, a 50' 12/3 of the thermoplastic with the 4 gang box on the end, please.
Assuming that you believe that will be enough to run power tools including welder off of with no voltage drop issues for the length.
mrb
I cant guarantee that since I have no idea what you are plugging it into, or what you are plugging into it. For example, if you have a 200' long branch circuit with #12 wire you will have voltage drop problems no matter what extension cord you are using....
That being said, i think you would be fine with the #12
mrb
How much for a 50' 12/3, shipped to 08009?
best way to ship a single 50' is USPS priority mail for $9.80. It should get to you in a couple days. Please note I am waiting on connectors to come in.
Bull
Gotcha. I believe that my electrician sized my cable from house to garage to avoid voltage loss over the run, but I do see what you mean about not knowing variables.
What is the typical size available at a "box" or local hardware store, for comparison's sake?
mrb
most of the stores carry all 3 common sizes, 16/3, 14/3, 12/3. The biggest difference with mine are the industrial grade connectors vs the lower quality molded connectors on all the store bought cords.
mrb
50' 12/3 is $9.80 to anywhere in US48 (never checked ak or hi) via USPS priority mail.
mrb
mrb,
Please check your pMs. I can only get on-line to this BBS during the late evenings. Ready to PPL for the drop cord combo.
Thanks man
I responded. Will go out tomorrow morning. Heres a photo of your stuff.
Vinko
Los Angeles
I'm still confused about certain kinds of plugs on extension cords and OSHA. I don't understand the reasoning. Not that there has to be, I suppose, but....
mrb
OSHA doesnt accept a cord with a metal junction box on the end of it. Thats not the intended use for the outlet box and the box isnt listed as such. If you need an outlet box on a cord that will pass an osha inspection, you need to use a rubber pendant box which is made for the purpose.
Here is a link to such a box http://www.woodhead.com/data/current1488/multiple outlet boxes 902.pdf
I have a project coming up where im ordering a ton of these so im going to buy some extras to have on hand.
mrb
if anyone needs a bunch of cables, say 4 or more, ill make a deal.
olds70supreme
Hello,
Would you be able to do a 25' 10/3 cord with a 20 amp plug (looks like this)
- l
o
It has a horizontal and a vertical prong.
If so, how much shipped to 56001?
Thanks.
mrb
I know I have a couple hubbell 20A male plugs, not sure on the female connector -I will have to check on that. I have some 10/3. I think youre going to be looking at around $50 shipped, maybe $55 if i have to get a connector.
Stargeezer
Central Nevada, USA
Just a quick note to say:
Just got my drop cord assembly and I'm impressed mrb . Professionally assembled using quality hardware-great packaging-fast delivery service-fair price-done right. Custom.
Can't beat that these days!
Thanks
mrb
I still have a couple hundred feet of the red 12/3 left, and quite a bit of the red 14/3 if anyone else wants some of these cords.
