Angle Grinder Cabinet
ToolSteel
Pardon me if this has been discussed before. I searched the Forum and couldn't find anything.
Has anyone ever made a cabinet to contain the sparks and metal dust kicked up by an angle grinder? I find myself grinding quite a bit and I'm constantly cleaning up an entire workroom. I've fireproofed the area around the grinding station, I always-always wear goggles, but I'm ashamed to say I've become a bit lax about wearing a mask.
I have a media blast cabinet from Harbor Freight which I suppose I could retrofit, but the enclosure is a bit small for an angle grinder. Any pointers would be appreciated.
ToolSteel
fatherof4
Long Island, NY
That stuff gets everywhere. Unless you want to frame out a section of your garage and make a grinding room, just bring the project outside.
T
ToolSteel
Actually, I do almost all of my grinding on the carport. I don't want to bother my neighbors so I stop grinding (or hammering) at 8pm. I was just looking for a way to keep the mess under control when I grind in my basement.
In the overall scheme of things, this isn't really much of a problem, but thanks for the input.
padronanniversary
Minesooooooota
If you go to fabtecbir any of those trade shows they grind at the show ..... Poor guy grinds all day but he has a plexiglass station where most of the dust and sparks are contained
zkling
A downdraft table may work for you, but even then with a 4.5" grinder doing heavy stock removal it is going to be hard to capture all the grit. I do all of my heavy grinding outside. If your parts are small enough a converted blast cabinet would probably work well.
PCO6
Newmarket, Ontario
I do some of my grinding outside too. My neighbours have 2 dogs that bark at me every time I go outside. My neighbours always apologize for the barking and I tell them it's quite alright. Honestly, it doesn't bother me at all. The good news is that they never complain about my grinding! I love those yappy little dogs. :lol:
bad_idea
Pasquotank, NC
Clamp a piece of plywood to the edge of the table vertical (for lack of better words, like a wall on the side of the table) a couple of feet high. Aim all of the sparks at that from a few feet away. That will stop most of the mess from spreading.
rburke65
Canfield, Ohio
I think it was on this site that I just saw someone post pictures of their 'make shift' grind "enclosure" made from a discarded washer and dryer. They were stacked, the bottom one used only to elevate to top unit to a workable level. The upper one appeared to be layed on its back, the base opened, used as a 5 sided box. I thought it was a pretty ingenious use of 2 appliances that were about to be thrown away.
zkling
I think you are thinking of Sberry. He has all kinds of ingenious repurposed stuff.
