Volkswagen tools
signcrafter
Against everyone's advice my sister is most likely picking up a volkswagen jetta this weekend. It's her money and her car so if that's what she wants she will get it. So this means I will have a German car added to the fleet of family vehicles I take car of. As much as everyone put them down I don't mind fixing things for family, they buy the parts and I always make sure I get some tools out of the deal so I don't mind wrenching on them. I also make them buy a factory service manual for vehicles I work on.
The one she is looking at is a 2001 with 90,000 miles on it. Not even sure if it's the 1.8 or 2.0 yet. Guess it needs new brakes so will have to do pads and rotors right away. Also I'm not positive what VW interval is for timing belt but it's probably at that milage so will probably do that right away.
What specialty tools will I need for these two repairs or any other common vw repairs? Any specialty tools for the brakes? Is there any tool needed for the timing belt?
xurusaibobx
best advice coming from a euro mechanic, stay away from VW only asking for trouble. You know that VW ad they had during the superbowl how every 100k vw out there the factory worker grows wings and VW has the highest amount of cars on the road over 100k i highly doubt that. if it is then its now with the same transmission or engine. theres so many problems with those VWs most times i tell the customers its not worth fixing. 60k timing belt
timing belt you might need the tensioner tool but you can use a snap ring plier as well. rear brakes you need the caliper tool kit ( the one with the disc you force spin back piston in) lost of money because everything on those vW tend to break after 60k. including and not limited to Door handles interior ECU Throttle body electronics fuse box spark plugs wires shocks dash ac compressor etc.
on the bright side if you doing all the work expect to see the car every other month for repairs
BajaBound
Nor Cal
Triple square sockets. I own the deep and shallow set from VIM and they are an incredible value. Metric tools are obvious but I would wait to see what she gets and then look up specifics. I own to newish vw's and they are great cars. I would prefer the 01 jetta over a lot of cars.
zx2slow
New Hampshire
I don't think I will be taking any of my VW's around your shop any time soon...
Get a set of triple squares, just started a thread and vim is a good brand. If you want to get serious about diagnosis getting a Ross tech vagcom cable is needed.
They aren't unreliable when maintained properly and with quality parts, they are over engineered and have their quirks.
STANIMAL
chicago
It needs a belt and pump now and a transmission in a few miles . If its a 1.8 , then most likely a turbo .
And I love EuroVans , but they are all trouble in my experience .
zx2slow
New Hampshire
The 1.8t needs an occasional Itialian tuneup or the turbo will sludge up. It's seen on cars with automatic transmissions more often as they are normally driven more conservatively. The 2.0 and vr6 are fairly sorted out and go forever.
Tarheelgarage
NC
no special tools needed; just a big 'ole pile of money when the repairs start coming in.//
Her purchase of this POS will help some tech keep his family feed and clothed....
Bigplum
Cotswolds England
It'll be fine , that's not a bad time period for VW's ,( the later ones get a bit daft with electric parking brakes etc)
The 1.8 T suffer from oil problems if services missed or wrong oil used, so get on that straight away
( the turbo bakes the oil into sludge which then causes oil starvation )
I would not recommend revving the **** of it without knowing service history
The brakes might need a XZN Spline bit ( I think you guys call it a triple square)
vagcom is a very good diagnostic tool , the cheapy chinese knock off ones on eBay are a pain
Faulty brake light switches cause a engine light to come on , dead cheap to replace
Water temp sensors fail around 70k Again dead cheap
cotjocky
Front calipers should require a 7mm hex. Rear will be a 13 and 15mm wrench. You will need a brake caliper tool to spin in the rear calipers. If you are replacing the rotor, you'll need a #3 phillips or triple square bit (holds the rotor on the hub).
Yes, you will need specialty tools to change the timing belt if you do it right. The tools you'll need will depend on the engine. 2.0, 1.8T, VR6 or 1.9 TDI.
The ALH Engine code 1.9 TDI timing belt kit from Metalnerd will run about $240.
Go here if you want factory specialty tools at a reasonable price and delivered quickly.
https://vw.snapon.com/Home.aspx
Banjorear
Essex Co., NJ
Sad to hear things haven't changed with these trash bombs. I had a German made '85 GLI that I ran the snot out for 358K miles. Just did regular maintanence and religious 3K oil changes.
Reverse went out and the fuel pumps kept burning up in it, but other than that would not hestitate to driving it accross the country.
Once they moved production to Mexico, quality went straight down the turlet and I wouldn't take another VW if they paid me.
Adam.C
I had a great experience driving my made in puebla 2002 VW beetle turbo S. Never broke down. Only in the shop twice, recalls both, over the course of 90,000 trouble free miles.
Puebla had trouble with wiring which initially resulted in electrical gremlins. Could have been environmental or a quality issue. That problem was solved over 10 years ago (late 90's).
VW drivers (like other Euro car drivers) like to drive and are in tune with their cars and the internet. So every flaw gets amplified. This skews popular opinion and consumer reports polls. Every luxury car has the same problem... their demographics, not their engineering.
I can't say all VW's are flawless, but I would take with a huge grain of salt anyone criticizing an entire brand of vehicles (including domestics) based on their personal experience. Modern cars seem way better than the cars I grew up with.
I recently bought a used (09) land rover, admittedly worried about their notorious reliability problems. 7 months in and just crossing 45,000 miles, this car remains faultless. Fantastic to drive and flawless in everyway. This is the kind of comment that typically doesn't find it's way to the internet.
signcrafter
Thanks guys. I'll have to order some triple square bits, don't have any of them. Do you think these will do most of what I need, http://www.amazon.com/dp/B000I1Q60O/?tag=atomicindus08-20. Or do I want one with longer shafts? Probably both but if you had to choose one for now which one would you want?
I have the brake caliper tool to wind the caliper back in. Don't think I have a 7mm hex, I have a 1/2" drive set that has 6 and 8mm in it. Will have to pick up a set of 3/8" drive metric hex.
That vagcom looks pretty nice and not really that expensive from a quick look at their site. Will have to look into that if electrical problem come up.
I see the timing belt tensioner takes a special spanner to adjust it. Will have to pick one of them up from schley.
DieselSaves
Big Sky Country
Get a Bentley Manual! The Haynes and Chilton are useless on these cars. The girlfriend has a 2000 Cabrio, and I have spent a lot of quality time with it.. :)
http://www.bentleypublishers.com/
-Sam
+1 on the Bentley manual.
Timing belts every 90k, don't wait on those. If it's an auto, start having the fluid and filter changed now. Turbo cars need the bigger filter and 5/30 synthetic. Do this stuff and the cars will last. Also, try this site. Http://www.germanautoparts.com Caries parts and manuals.
Approach fixing VWs with an open mind. They are not American or Asian. They have their own way of doing things.
signcrafter
I do have an open mind, taking all the hate with a grain of salt for now. May come back to mite me but who knows.
Above someone said timing belts at 60 and you say 90? Think in another thread someone said 70 also. Anyone know for sure when the timing belt needs to be changed? I'm going to change it right away anyway but just want to know for future.
For the manual will something like this work, http://www.ebay.com/itm/VW-OFFICIAL...s=Make:Volkswagen&hash=item19e96e70c8&vxp=mtr. Says it's the official factory repair manual. I've had good luck with factory manuals on disc on ebay for other cars.
Robochan
Timing belts every 90k, don't wait on those. Do this stuff and the cars will last. Also, try this site. Http://www.germanautoparts.com Caries parts and manuals.
Wow im shocked at the hate towards VW. I work in an a shop that specializes in euro cars primarily Porsche and Audi and they can be ultra reliable.
The jettas are very reliable, if you neglect them, they break. We have customers with 300k miles on 1.8T and 2.0. Dont skip oil changes or services and they will treat you better than any other car like it.
You cant treat them like a honda and run 20k on cheap mineral based oil and never do service.
RKA
I've been an audi fan for nearly 15 years. Both Audi and VW's are very nice cars in my book, but not for the faint of heart. In my experience the failure rates are 3-4X's higher with them compared to the Honda/Acura's I've owned. And the parts prices are often very high as well. That said, a well-sorted 5 year old German car (or Mexican as the case may be) feels a lot more solid to me than a brand new japanese car off the line. But, it takes a special kind of person (patience and money) to keep that german car "well-sorted"! :) I put up with them, and they certainly test my patience, but when my family, who love the reliability of Toyota's and Honda's, ask about a VW and Audi, I steer them away. Even my wife has no tolerance for it. She rolls her eyes every time I tell her I found another issue with the Audi. ("why don't you buy a new car?")
That said, here are my thoughts.
If it has the 1.8T engine, in the A4's, those engines threw timing belts as early as 60K, even though Audi recommended 90K. The tensioners would **** out. If it's a 1.8T, I would do the TB now and every 60K thereafter. Water pump and thermostat as well while you're in there.
Skip the triple squares until you need them. CV job or anything that requires removing an axle will require them. For now just get that metric 3/8" allen head socket set. You will use those everywhere.
Brake tool - yes. 13mm ratcheting wrench and a super thin 15 mm wrench to counterhold the brake slide. Cycle shops usually sell that later, which works quite well. Vag.com - yes. Not just useful for electrical stuff. These cars have sensors everywhere, so being able to pull the codes, read the measuring blocks, etc. is very helpful. Can't own an older Audi/VW without these imho.
Start thinking about replacing the shocks. By 75K they start to deteriorate rapidly.
If that engine has coilpacks on it, keep at least one on the shelf for emergencies. Or for $100, replace all 4 and leave the originals on the shelf for emergencies.
If you have a turbo motor on that car, do 2 oil changes at 500 mile intervals with regular dino oil. If there is sludge in the system, you'll see it start to flush out, if not, great! Then switch to the recommended weight synthetic and stay on that. You should be fine at 5K intervals.
Watch out for plastic bits in the engine bay. If you touch them, fully expect them to disintegrate in your hands. If you don't touch them, consider them suspect anyway. When the car throws a code, there is a 50% chance it's one of those plastic bits under the hood.
Replace vacuum hoses. They will likely be brittle and ready to go. If the car has a diverter valve, replace that too.
Check for coolant leaks. The reservoir cap and hoses are likely suspects, get a visual on the end tanks of the radiator (probably plastic - remember what I said about plastic bits).
Wheel bearings - throw it around some on and off ramps and listen for the tell tale sounds. If you're doing the suspension and one of the wheel bearings are bad, may as well do them together. Do the wheel bearings in pairs. Usually the other side is within a few K of going bad anyway.
That's the stuff that comes to mind. If you have a good basic collection of tools, I wouldn't go crazy buying tools until the need arises.
Banjorear
Essex Co., NJ
I'm all for a challange, but a "tight" car is no fun to drive when it won't run right. That is a very extensive list of things that are ready to or likely go while driving.
As others have said, if you want a car that you can hit the key and go without a worry, VW's aren't it.
zx2slow
New Hampshire
I don't think anyone that's peddling the "Hurr durr VW is bad" line has actually owned and properly maintained a VW.
The switch from VDO to Boch electronics in the late MK3/early MK4 brought real problems, they were resolved within 2-3 model years. That was 15 years ago but these "experts" keep parroting the same garbage line time and time again. The MK5 and onward are absolute tanks and have no real problems, just quirks that would mystify any dimwitted mechanic that can't understand that Germans might do things a wee bit different than the Americans and Japanese.
RKA
I guess it's all a matter of perspective. We're talking about a 13 year old car with nearly 100K. Most of what I mentioned were age related or normal maintenance items one might expect with most cars this old. A few were a "heads up" about things to watch out for to keep it reliable. You can fix or replace when it actually fails or do it proactively. But don't let my lack of brevity reflect poorly on an unsuspecting VW. :beer:
top drive
Aberdeen , Scotland
My experiance with vw is expensive parts and it needs lots of them.....
Our golf had 75k on the clock when i got it at 6 years old , full book of service stamps and reciepts for services and still only lasted to 98k.
The steering rack went , the headlight wiring failed completely, the water pump died prematurely -genuine vag metal vaned water pump fitted just before igot it , died within 25k. Water ingress into the boot and it ate front tires due to the camber needed just so it went round corners as the handling was so awful.calipers were all in various states of siezing over my time of ownership.
Wont another.
Now i buy cars folks hate - cheap to buy and cheap to fix it seems.here folk rave about vag and throw good money after bad to keep em on the road.
treblarefils
VWs were meant to make mechanics out of every owner lol. I would never recommend one to anyone that isn't handy around a car. I have a 2002 1.8t golf and it is a nice car car. unlike Hondas and Toyotas these cars REQUIRE maintenance not in a bad way but in a you cant forget about it way. I love VWs. Most definitely you need the 3/8 hex set. Lots of torx used also. Post above covers pretty much everything. Mine had a cracked coil harness very common when I got it but I replaced it with a new oem full engine harness cost 90 bucks and a lot of time. Get to know www.ECStuning.com they are great.
jc5205
Get A Bentley repair manual, a vag or ross cable to hook up to the computer
Parts/Tools etc - http://www.ecstuning.com/
If its a automatic, change the fluid asap - I did this to my daughters bug 155,000 still going
Don't buy anything until you need it.......oh wait, your gonna need it
cotjocky
Regular Snap-on 15mm fits just fine. Just an FYI.
Moose-LandTran
The Brink of Insanity (England)
As someone who works mostly with VW-Audi, and in particular the MK4 Golf/etc platform some of these replies are just funny.
We've had a Golf in our family for 13 years. I've had 2 Golfs as daily drivers (currently a 1.9 TDI wagon) and all have been largely trouble-free aside from routine maintenance, a few things that died over the years and a persuit of perfection for my wagon. (Money is not an object with the wagon, it wants for nothing.)
I don't know what it is with Americans and VWs, either you guys are really hard on them or are scared by anything that has advanced beyond pushrods and live axles.
Red Green
South Central Michigan
My Girlfriend had a 98 VW Bug with the 2.0 She beat that car like a rented mule. It lasted 225,000 miles until we unloaded it. I think VW gets a Bad name because they are different then most US cars. Being that old I would recommend a new radiator cap. I have seen several that were bad.
AV tinker er
SoCal
If it hasn't been said yet, get a 12 point 30 mm for the half shafts. And your replacement will almost assuredly be a 6 point....
billymade
New Mexico
The #1 best tool that I have gotten for my 2000/2002 1.8T New Beetle:
ROSS TECH VCDS/VAGCOM; it paid for itself, the first time I used it and I have never regretted purchasing it. Its the real deal and has a depth to it, that rivals the factory VW scan tool, the dealership uses.
Get the genuine; full version: $250-$350 depending if you want to scan later models with CAN BUS, the latter will let you scan the latest models shipping from Volkswagen, Audi, and others in the VAG family... (VCDS License with HEX-USB+CAN: All VAG). Unlike, most professional scan tools; the updates are FREE for life! It truly is a bargain and will help keep your VW on the road; every time I use the tool in a new way, I am amazed at what it can do! For many years; I have just been scratching the surface of its capability (using the "auto scan" feature), now I am doing things like: matching a new instrument cluster to the ecm, matching keys, reading fuel trims, setting rediness, doing output tests on components (everything from checking your speedo cluster; to doing a age test on your converter, etc.) and adjusting my fuel gauge... the possibilities/functions, are pretty amazing!
The cheaper way; is a Chinese clone cable and $99 VCDS lite; I recommend going full; guaranteed to work and excellent support from Ross Tech.
If you want to just do scanning with the VW specific factory codes; check amazon for the cheaper stand alone, hand held units.
On the low end VAG305 and a step up is the current model VS450; just does the basic scanning for codes needs, the Ross Tech VCDS, has an incredible depth that can take some time to learn its advanced features and then couple it, with the excellent Bentley or online VW factory Erwin subscription, to guide you through the testing, adapting, and repairing end of things. There are higher end hand held units, that do live data and other adaptations etc. but you are quickly going into VCDS territory, which is the industry standard and does pretty much anything, you would want to do. VCDS does require the use of a Windows based PC; a laptop, makes things easier and more portable but you can use a desktop as well (they sell a USB extension cord; to reach your vehicle in a garage setting).
vwvortex; is a good resource and while it has its reputation; there is tons of great info and insight into your particular car.
dogdog
everything RKA say is true... I owned the MK4, replaced almost everything under the sun in that car as far as parts goes especially the plastics pieces. for a German car this is a POS. and I bought it new. trouble starts just when the warranty expires. anyways enough ranting....
aside from your standard metric sockets usually 10mm 12mm 13mm 15mm 17mm 18mm up to 21mm 22mm for the shocks/struts 29mm for your coolant switch. 32mm/30mm for your axle nuts.
a good set of metric hex.
good set of torx upto T50, mostly T20 T25 T30s if you work on the body.
Triple square sockets if you work on the door lock / cv joint.
and that special engine bolt tool that looks like triple square / torx if you worked on engine head bolts (some)
if you are doing the timing belt there is a timing belt pensioner wrench which you can make the holes are 17mm apart between center the prongs
8 9 10 mm wrench if you decide to bleed your brakes. Aside from those, a brake press kit from HF is really helpful for rear brakes.
bubble flare tool if you wanted to replace the brake hard lines on the body.
an ebay $15 vag-com usb cable for your ross-tech software if you wanted some sort of diagnostic that is more than odbII. or spent $299 for the full blown vag-com unit from ross-tech.
an usb-tacho dongle if you wanted other hacks
a good set of multimeter these cars have electrical gremlins build in. Especially if your car is manufactured from the Mexico plants like mine.
rick carpenter
Huntsville, East Texas
I don't know the lengths of longs and shorts, but I had my 3" long M8 cut down to 1.75" so I could use a 1/2" ratcheting wrench on it to tighten the triple-square-headed door hinge bolts. (This way, you don't have to remove the fender to get at them.)
AV tinker er
SoCal
All these rants, it seems people either have a great VW or a lemon. I had my 00 mk4 2.0 for 8 years (bought it used), drove it every day. Only left me stranded once when the alternator went out at 180,000ish. Other than normal wear and tear she was a great car. Hated to see her go.
One piece of advice, if the AC needs to be serviced both cooling fans will surge on and off if the ignition is on. I never traced the schematic through to figure out why that was/is.
dogdog
ecstuning is good for odd ball parts that most autopart store don't sell aside from dealers but not cheap either they are about 15% more than others cheaper than dealers in some cases.... go rockauto.com first if you are just going for regular maintenance parts.
dogdog
VWs were meant to make mechanics out of every owner lol. I would never recommend one to anyone that isn't handy around a car. .......
hahaahha this is so sad so true... made a vw mechanic out of me from doing all the part swapping, diag of weird issues, weirder electrical issues. Bushing replacing master by now.
