stockshock
- Joined
- Apr 11, 2012
- Messages
- 7
I bought the compressor with no motor to hopefully have something that will deliver the cfm of my dreams!
But I now have an issue, I cant find any numbers on the compressor to identify it. I see the numbers 9050 or 9030 on the right most cylinder(sleeve) base. I have seen compressors that are really similar like this one:
http://equiptool.com/i-4600058-bend...5hp-80-gal-vertical-tank-for-export-50hz.html
and this one:
http://allaircompressorparts.com/rf20s2hp1stage3cylinderreplacesfushengta-65orcurtises-20pump.aspx
I would like to try and find the manufacturer of the pump so i can order replacement parts and see what size motor and what speed i need to run it.
thanks!
the pictures are of what i have currently.
But I now have an issue, I cant find any numbers on the compressor to identify it. I see the numbers 9050 or 9030 on the right most cylinder(sleeve) base. I have seen compressors that are really similar like this one:http://equiptool.com/i-4600058-bend...5hp-80-gal-vertical-tank-for-export-50hz.html
and this one:
thanks!
