bigcaddy
I've got a small Honda WT20X trash pump at my office and its mechanical seal is leaking. I have no idea on how to remove the impeller so i can replace the seal.
There is no manual with the pump and the web has been generally useless.
Normally it would be a bolt with left hand threads but this unit has a cast 15/16 nut on the face of the impeller with no visible method of removal. No set screws to loosen and the impeller just spins with the wrench or socket if you attempt that route.
Any help would be great since i plan on tackling this tomorrow morning
Ive provided so pictures of the impeller so you can see what i'm working with. I'm pretty much stumped on this one.
Most of the ones I've fooled with were both standard right hand threads. Usually the rope or a dedicated piston stop is the factory recommended method.
