"Oil containing an adhesive"
organ
Atlanta
I recently bought a Sawmaster power hacksaw and the thing has 8 oil cups! The manual says to use an "oil containing an adhesive" for the slide bar cup. What would be a good choice? Chainsaw bar oil? Maybe motorcycle chain oil?
SteveCh
Never have heard of an adhesive additive. Chainsaw bar oil has an added "tackifier"--not sure of the spelling--which makes the oil stickier to prevent its flinging off the end of the bar or dripping off the chain. No idea whether that is what they are advising in your case. Someone will know....
SteveCh
They do make variations in bar oil, a winter version and summer version. The winter is thinner. Some folks dilute summer wt. with some diesel rather than keep two different viscosities around.
woody 73
The Great State Up North
Wow by chance I was watching one of the car shows last night on tv (maybe Fast N' loud), in rebuilding an engine they used the wrong oil for the break-in, one of the guys did put in adhesive but it was not enough and they destroyed the new engine upon start-up.
Something along these lines would have saved them for the first start-up.:
http://www.royalpurpleconsumer.com/products/royal-purple-break-in-oil/
bonneyman
Desert SW
You know, a certain bike parts maker used to use a grease in their index shifting levers that had a slow-set epoxy in it. or something. It slowly hardened over time, eventually locking up the system so you had to buy another. People only found out about it because they put too much epoxy in at first, and the things were locking up during the warranty period - which they then had to replace free! :lol_hitti
After that, they slightly adjusted the % of epoxy to get past the one year.
Maybe their reasoning was it was an adhesive to retain the grease in those levers?
MatBirch
Filer, Idaho
There's a display I've seen on the counter at auto parts stores- clear plexi with white plastic gears that you turn with a crank. The untreated side, the oil slides right off, of course the treatment makes the oil cling and climb all the way up... Can't remember the name, anyone seen it?
NKlamerus
Springfield, Or. (From Florida)
I know exactly what your talking about. It's Lucas Oil additves.
Milton Shaw
The phrase "oil with adhesive" probably has been translated by someone with textbook knowledge but not real knowledge of English. Probably means a thickening agent or viscosity improver like the mentioned Lukas Oil.
zkling
I would use a good way oil. It will have the stickyness needed to lubricate the slide, yet still be able to flow through the cups. Do the cups have felt wicks in them?
Fretters
South Yorkshire, England
It's likely the word 'tackifier', which SteveCh mentioned, which has been misunderstood. Commonly used word for describing way oils etc.
O
organ
Atlanta
The bar cup didn't have a wick in it when I got the saw. I've since put a piece of felt in there because it's one of two larger cups and the other had a wick in it. Where can I buy way oil?
dr_clyde
Holland, MI
Any industrial supply will sell way oil. Grainger, MSC, McMaster, or any of the local tool supply houses.
