I recently bought a Sawmaster power hacksaw and the thing has 8 oil cups! The manual says to use an "oil containing an adhesive" for the slide bar cup. What would be a good choice? Chainsaw bar oil? Maybe motorcycle chain oil?
There's a display I've seen on the counter at auto parts stores- clear plexi with white plastic gears that you turn with a crank. The untreated side, the oil slides right off, of course the treatment makes the oil cling and climb all the way up... Can't remember the name, anyone seen it?
The phrase "oil with adhesive" probably has been translated by someone with textbook knowledge but not real knowledge of English. Probably means a thickening agent or viscosity improver like the mentioned Lukas Oil.
The bar cup didn't have a wick in it when I got the saw. I've since put a piece of felt in there because it's one of two larger cups and the other had a wick in it. Where can I buy way oil?I would use a good way oil. It will have the stickyness needed to lubricate the slide, yet still be able to flow through the cups. Do the cups have felt wicks in them?
