fabricated tools that make your life better!
Vegaman_Dan
Pacific, WA
Working under a car with a lift means you have this huge light blocking thing overhead. Drop lights are useful, but finding someplace to hook it can be tricky. So I took a pair of locking pliers, welded on a tab with a hole drilled in it, and mounted a cheap desk lamp with bendable stalk on it. Now I can clamp it to any handy surface while working on stuff.
Sometimes it's the simple things that are the most fun to make.
E
E.rodz
st.paul MN.
agreed this is a perfect example of great ideas come from everywhere and everyone! thanks for posting.!
Vegaman_Dan
Pacific, WA
Got tired of my 3/8" impact sockets being loose in my socket drawer. My normal sockets are all on rails, but the impacts- well, dedicated sets tend to be less used so I like to keep them together. The problem is that even the simple sliding rails with clips on them are simply too long for holding only a dedicated set of sockets. All that excess flopping about the drawer makes it awkward to use. And it's not like you can't just cut the rail down to size...
...Wait, why can't you?
A couple of minutes later, I had the rail cut down to the size I wanted, cut end rounded and deburred, now ready for use.
I took the opportunity to use a paint marker on the sockets for identification. I know it's not pretty, but finding the socket I need when I need it is more important. These are sockets I use, not to look at. :)
beakie
Ontario, Canada
if those sockets have the stamped lettering/numbers, grab a white/yello grease pencil and fill all the numbers in. makes seeing them at a glance much easier, still looks pretty good too.
LWaite
Denver
I use these to shape metal
Ruger_556
Flex head Craftsman ratchet in the back of the drawer... You can't buy that one. Took a breaker bar handle and put it on a ratchet head (To get the extra length). The offset is to reach around Eaton truck rear ends to get at one bolt.
raddksn
south central upper peninsula michigan
Thread of awesome candidate right there!!!!
Youngwing
Didn't exactly fabricate just slightly modified to serve a better task 8 mm bottle opener
Chris Stapley
Campbellford, Ontario
Couldn't find a few body panels I require for a custom car I'm building and have always beat stuff over a stump before so it was time for an English wheel build. Used an airport runway sweeper broom pressure adjusting jack for my adjuster ( a glorified 5000# trailer jack really that I happened to have in my warranty bin ) a very high quality caster wheel that I machined the urethane tire off for the upper wheel and a set of anvils from Princess Auto ( our version of Harbor Freight ) that I finished polishing and they are great.. The rest was odds and sods of tubing I had around. I used 4"x4" x 3/8" for the main frame , the legs unbolt so that when I have a dedicated wall spot in my shop I can actually hang the wheel on the wall to swing out of the way when not in use and bolt the legs on when friends need it too.. Oh yeah,adjuster wheel is a 16" BMX wheel with tire , makes for adjusting very nice with the slight kick of a knee.
fnieto
Tucson,Arizona
built this jig to support a third member for setting up pinion/ring gear and install of ARB air locker.The secure platform was essential for magnetic base dial indicator measurements. The CNC plasma table used to cut this jig is made from 80/20.
Beemer533
Syracuse, NY
Man, there is some awesome stuff here!
This doesn't really compare, but it got the job done in a pinch!
I was installing some large solar stations with adjustable legs and the place that hot dipped them didn't protect the threads: solution, one extra heim and a grinder with a cut off wheel! Worked quite well as an impromptu thread chaser.
It also ended up serving double duty later on... You can see some orange paint on the bottom; I was laying out some sonotubes for a set of stairs at my house and realized I didn't have a plumb bob!
E
E.rodz
st.paul MN.
I just got around to reincarnating an old riveter that I picked up in a garage sale years ago and fabricated a holder for some tooling with a scrap piece of alum..also fabricated a new push shaft and new end on the foot pedal. now lets see what we can make with it!
KerryH
Ga
Erodz that is badass!
E
E.rodz
st.paul MN.
lol. I thought I was done but after using it the other day I guess not more stuff coming up on this one!
E
E.rodz
st.paul MN.
nicklouse10
Edinburgh, Scotland.
Here's an incredibly simple tool I made for compressing/removing valve springs and changing stem seals/collets. It's literally just a piece of flat steel bar about 28" long with a hole in it, a slight bend near the end and a slot at the tip
It's nothing as intricate as most of the fascinating stuff you guys have built but it works perfectly for the job it was made for so I thought it was worth posting
I used some polymorph plastic that I got from ebay (small plastic granules that go soft and malleable when placed under hot water) I moulded some into 4X blanking plugs for the combustion chambers so the valves have nowhere to go
Here's one of the the moulded plastic plugs:
Just pop it over the rocker stud, screw on a nut a few threads to act as the pivot and then lever the spring down.
Now I've used it a couple times I've learned to stick my shoulder under the bar and lever it up that way so I have both my hands free to work.
Using this tool I can swap out the valve springs on a pair of heads in under 10 minutes for both heads
Here's a video of the very first time I used it
KMinAF
Fairview Utah
The riveter is pretty cool but the way you painted the door is what caught my attention!
shortykorte
Tallahassee, Fl
I needed a cover for my homemade parts washer and had a sheet of old galvanized laying around. I clamped the sheet to the work table and hammered a 90 on all four sides. Simple and free.
shortykorte
Tallahassee, Fl
Building the wash cover gave me an idea to make my To-Do whiteboard more useful. I have these magnetic label holders that I will use to keep a list of my projects. I cut a small piece from the scrap galvanized, roll the top so it could hang from the top of the white board. Sanded and cleared it so I could have that shiny industrial look. I also thought it could use a little decoration so I added a decal I had stored away.
shortykorte
Tallahassee, Fl
Forgot the pixs.:lol_hitti
Garage5.9
Maui,Hawaii
Needed to drive out a pin but didn't have the proper attachment for my air hammer and all I had was a dull chisel so I welded a plug to the end and it worked like a champ
manimal
I made this guy to help with my engine swaps. The Greenlee L97 has a laser built in and is intended for pipe work.
Bolted to the transmission output flange I can move the motor around until I get it situated where I want it and then make the engine and transmission mounts with out guessing.
Ed ke6bnl
Agua Dulce, Calif.
When I did my motor/trans to rear end I had the motor tilt down 3 degrees and the rear end up 3 degrees and the centerlines ran parallel BUT not aimed at each other. Just what I read and learned???
larry_g
oregon
In my experience the crank does not point at the pinion. What you need to achieve is having the C/L of the crank run parallel to the C/L of the pinion. What you have does not assure this. Are you using any other measurements, like using an anglefinder, to assure that the center-lines are parallel?
lg
no neat sig line
