Streetbu
You still haven't spilled the beans on the name you picked out for the business? Keeping it under wraps for awhile longer? Great job BTW and I can't wait to see the new shop finished!
You need to turn the tee;s up at the split off locations go up then back down off the feed line. I'm like others BLk pipe is best for air lines Not PVC
Mark, I'm with the other guys in suggesting that you reconsider the use of PVC for your air lines.
Also good suggestion for the tee with a drop tube at each outlet, I used ball valves before the outlet on the down pipe and another ball valve on the drop below the outlet for draining condensate. Copper lines, flex line from compressor to the copper, solenoid with a timer to auto drain the tank.
Here is a link to a discussion on PVC
http://www.garagejournal.com/forum/showthread.php?t=60109
Terry
I agree that the black pipe is the best way to go. I have PVC in mine and I know it's not safe and I don't like the way it looks.
I will be in Bradenton in April visiting my parents, so I will get bored with nothing to do, so I will offer free labor to lend a hand.![]()
Look into spray foam insulation after you get the siding repaired. I have seen it done on many projects & recently have done some research on it. We are going to get our house done (attic & crawl spaces / basement for now) in the next week or two. It really is far superior to fiberglass.
Last year I was working in a high end resto shop where all of the air from two very large compressors is run via PVC. The lines are 23 years old with no problems in all that time.
I installed miles of Steel air line in the 70's , nearly all of it black steam pipe fron1" to 4" . It's a major hassle installing hard line like that today and seriously expensive.
Designing an air line layout should start at the user end , by working out how many outlets,droppers etc then work backwards by adding air dryer/separators ,automatic water drains etc with a definite fall in the line from the compressor end . That means running up into the roof with branches off to the out lets as down pipes. Doing this in steel would take at least two weeks solid work in a shop of your size. And Copper? do you realize that copper is more valuable than gold? Best get some serious prices before even thinking about copper. If you are considering building a spray booth,get a refrigerated air drier to run both the spray guns and the respirators . The booths air needs to be throttled down too,you don't need 120PSi in a spray gun and this case a separate air circuit just to supply clean air is a winner.![]()
This is a link to a solenoid with a timer. Just hook it up to the drain at the bottom of your air tank with a discharge line, set the timer for how often and how long you want the valve to open and you shouldn't have to worry about condensation in the tank. Not sure of the brand name I used but found this one on line as an example. Mine is 115 volts.
Nice work on the shop, Mark. A big project like that takes a lot of little bites to get done. Keep on going.
For the floor plans, if you need a PDF or JPG, send me the AutoCAD file and I'll print it for ya.
Man, that battery is a Beast! So a forklift is not like a cordless drill where it's cheaper to buy a new one than replace the battery!
You have made many GJ'ers happy with all that copper!
I have been away from the site, and missed the debate on PVC vs. Hard Line. But I willl add a comment anyway.
Everything is a trade-off of time and money - but keep in mind it is a lot easier to do now, than to go back and change it when the shop is full an running.
** Great new building by the way.![]()
At this point we are sanding all of the body down and fixing it right. All body lines and repairs made out of fiberglass as they should be. I am so proud of the guys in the shop. They really know what they are doing and they are doing it right. This really is going to be a car to be proud of when it gets done.
Yes sir they work real good, we have the same one here at work when my guys do a/c work on the big trucks ( peterbilt trk ). Just hook and press start. Nice
Man thats a very nice garage set up
Just finish reading from the beginning subscribing awesome
Mark,
First time I've posted, but been reading along the way. Enjoyed your first build.
My main reason of this post is to say thanks for making the decision on the hard piping, knowing how much more it cost. You're keeping you, employees and the many people that'll visit the shop safe.You're keeping in theme by using the copper, show class airline for a show class shop! You could buff and clear cost the drops, it'd really stand out.
Being I'm less than a hour from you, I hope to make it by soon.
Also, my offer from last year to cook for one of your gathers stands. I'd love to be in the company of fellow shop nuts with good food and beer.
Craig
My love of cars came from the 70's when I had a chevy van. My motif was "Keep on Truckin"
So, you do take adoptions??? Only if I were closer!
Nice van. I see the edge of the traditional 'Keep On Truckin' sticker on the side!
Brady here, and thanks for letting me participate in the fun Mark! I hope to make it down there again this week, just busy with the kids over spring break. For all of you who haven't been able to meet Mark and his crew, they are great people, and I am very fortunate to glean as much knowledge from them as possible!! Top notch folks.
Really enjoying this thread. Been following it from the start. 100 pages and almost 2,000 posts. All of them a pleasurable read. Looking forward to more good stuff as you make the new building your own.
Thanks for the great reading! it has been fun to watch this thread grow into a legend! And congrats by the way. You have hit 100 pages in this beast. Keep up the great work.
Darin
That is a beast of a man cave!
Mark, the first new vehicle I ever owned was a 1975 Ford Econoline shorty van. Lots of great memories, lots of miles driven. I've actually been looking for a '70's shorty van for a runaround vehicle but they're hard to find (in any kind of decent condition anyway). Keep your eyes open in Florida.
I think I can understand that photo more than many round here as I spent my youth in the 70's and my mom blessed me with very curly hair. So much so that as I grew it longer the more I was called that type of dog. LOL
You know what they say bout dogs and owners![]()
So how many times did you burn your leg on the Thrush Side Pipes.
Been there and done that back in the '70's also. Sure wish I had hair like I had back in the '70's too.
.......at the time there were many teenage girls in and out of this van and entrance was at the side door where many of these girls got a nice burn from those pipes.
I had the local plumbing wholesaler over to my building. The general manager showed up and as soon as he walked in he said "what are you going to do with those racks"? A deal was struck and they showed up this weekend with 6 guys and took them down. I kept one big section for myself.
What makes you need tubing that big for air? honest question
We have a 175 foot run from one end to the other. What size do you think it should have been?
The BendPak XPR-10A arrived today.Wow, 10,000 lbs of lift. This lift was priced the same as some of the cheaper lifts I looked at. Most of the other guys charge for shipping and BendPak ships for free. I am really excited to get this bad boy put up. I am so happy I decided to purchase the BendPak. I recieved a lot of encouragement from you guys and really happy I listened.
One thing you will notice is I sold most of the drive thru racks. It really happended by luck. Since I was recieving death threats from some of you guys on the airlinesI had the local plumbing wholesaler over to my building. The general manager showed up and as soon as he walked in he said "what are you going to do with those racks"? A deal was struck and they showed up this weekend with 6 guys and took them down. I kept one big section for myself.
We starting sanding the floors in the big warehouse preparing them for paint. I used an attachment that mounted on my floor scrubber. I got it from home depot and it works like a charm. It has some metal fins on it with carbide attached to them. The floor was pretty shiney so I decided to scuff them up before paint. I will hit it with the pressure cleaner tomorrow and then prepare to paint.
If there are any questions about what kind of pipe I am using for the airlines the next two pictures should answer it
We got the build/ clean room painted a few days ago and it really looks nice. At one point I was leaving bare concrete but after further thought I just couldnt do it. You can never get concrete clean and it holds so much dust. With the epoxy floor they are so easy to sweep and mop. We like floors clean around the shop!!
