I've been thinking about that too. Has anybody tried never-seize??
Is that stuff similar to Coppa-(Ease|Slip), judging from their site? Definitely does put even grease to shame on it's ability to get on absolutely everything if so. You find copper colour fingerprints everywhere.I've found that stuff, (whilst I do like it and have used it until recently on the vices), suffers most of the same drawbacks as standard grease though, (I believe it uses a standard grease base?). It dries out eventually and solidifies, and it clings to any and all crud which gets near it. That's why I'm on the hunt for a replacement. Was thinking that a beeswax and graphite concoction might be worth trying?
Cheers.Does that paste wax darken it due to some colour in the wax or due to having some minor type of reaction with the metal?
I think it is the chemicals/petroleum in the wax that reacts with the metal.
Thats is what I use. I think the metal has something to do with it also. Some slides will come out great with a wire wheel and or scotch pads and others just won't shine even with washing them in between to get the built up metal off. The more you try the worse it gets with black metal dustI think it is the friction and the miniscule wear from the cast iron causing the wax to darken and then fill the pours of the casting. What type of wax are you using? I've used johnsons paste wax (yellow can) for years on non metal cutting machinery and have never noticed a darkening problem.![]()
How well do those two hold up, over time? Furniture polish as in wax polish?
Somebody would buy those wouldn't they ?
"I also keep covers on my vises to protect them from the general shop dust when not in use"
Custom made Logo vise coversSomebody would buy those wouldn't they ?
Craftsman drill press vises, steady growing!
Never-Sieze has grit in it to help keep the grease from hardening. I wouldn't use it on parts that move often for fear of the abrasive factor.
It seems to be marketed as a "high-pressure lubricant" containing metallic and graphite particles. I would tend to think that it exactly what you would want on a vise screw....
Where did you hear it was abrasive??
Graphite itself is abrasive.
I usually use Red N' Tacky for my general purpose shop grease. :
I also keep covers on my vises to protect them from the general shop dust when not in use.
Hello all-
This is my first post here. I have been reading this thread for a long time and have been motivated to buy an old vise and restore it. I finally found a vise that I want to invest the time/resources restoring. It is an American Scale CO. Also says KC MO NO 522. It is a 6" vise that opens to about 15". I weighed it along with the stand it is attached to and it weighs 348lbs. If I had to guess, I'd say the vise weighs about 200lbs. I'll try to figure out how to put pictures up as soon as I can.
Thanks for the inspiration.
Steve
Vise cozies?
I'll stop appearing to be argumentative one day. Honest.Quite the opposite with graphite though. It's been used for donkeys years as a dry lubricant, and for good reason.
I'll try that! It says it is "fortified with Anti-Sieze", whatever that could mean...
Pictures of my American scale No. 522
I think that that vise is way too advanced for a beginner restoration. The best thing for you to do is to send it to me for storage while you practice on cheap chicom **** until you're ready to tackle such a difficult project.![]()
It's on its way. Hahaha! I am going to take my time on the restoration and make sure it's done right. I hope that I will have to buy many tools as an excuse to assure a proper restoration.
Steve
Do you use it on woodworking machinery that comes into contact with wood you plan on finishing?
No worries. Back in a former hobby I use to machine graphite nozzles. Used an old beater lathe and did it outside. Machining graphite you will realize how abrasive it is not only on the machine but the cutting tool life is drastically reduced. There is a local EDM shop that specializes in custom graphite electrodes and they use specially designed VMC's that have extensive way covers, again to prevent the abrasive dust and slurry from wearing away at the machine.![]()
*Note to self: I need a tree stump!
Star vise anyone? Don't know much about it but I figured I'd save the picture in case someone else ever runs across one.
