I got the new fine-grit wheel for the grinder. I'm still not sure if this or the wire wheel will be more useful, but I gave the new wheel a ring test and mounted it to see if it was true. It is, and the grinder now spins for over four minutes after I shut it off. It's possible that this is not a sign of how great the old bearings are, but instead is a sign that the bearings are just about out of grease. So time permitting, I'm going to pull the old ones at some point and source some replacements.
Speaking of grinders, here's a quick story that some of you on the board just might be able to relate to:
I've now got two good grinders: a 6-inch and a 10-inch -- and the 10-inch one is so big that it looks just a little bit clowny in my small garage.
But there's a kind of inertia to a project like this -- where you start looking for something, and you track a few different versions of it, and you think about alternatives, and you get tempted by bigger/more-powerful versions of whatever it is you're putting together. So that even when you're done -- as I am now with the bench grinders for my shop -- there's a part of you that keeps looking and keeps thinking.
So I mentioned earlier in the thread that there is the 2-hp Baldor buffer up on Ebay. Now, I don't need a buffer. But there's a 12-inch Baldor grinder with those specs that lists for about $3,000 and is, well, awesome in every way -- AND IS ALSO MUCH, MUCH TOO BIG for my two-car garage. It's also MUCH, MUCH TOO MUCH GRINDER for the sort of fabrication work I do. (Emphasis mine, because it's all true.)
But still, it's a 20-amp grinder. It's be a blast just to turn the thing on. And it's got even more power and bigger wheels (2"x12"!) than the big Milwaukee I just fixed up.
So naturally, my mind got rolling.
The same place auctioning off the 2-hp buffer is also selling a 12" Baldor grinder that is probably going to be tougher for them to sell, because it's 3-phase. At least, based on the model number, which I was (kind of) able to make out in their picture, it looks to be the 12-inch 3-phase model. The description is basically useless and the pictures are fuzzy.
But I looked at both of these and I got thinking about the possiblity of mating the 2-HP buffer to the wheel covers of the grinder -- the buffer shafts look longer, but I'll bet I could fabricate a workable spacer. I could get the buffer for $300 and the 3-phase grinder for $150 and sell off the pedestals and probably end up with a $400 12-inch monster Baldor grinder.
Which I don't really have a need for.
And which is MUCH, MUCH TOO HUGE for my garage. Take a look:
So naturally, I almost bid on both items. But only almost. As I thought about it last night, I just couldn't see a way to fit the thing into the layout of my shop -- and still couldn't come up with a grinding job in my future that the 10" Milwaukee wouldn't manage with ease.
Still, it was difficult not to bid. Fortunately, I was traveling when the first auction closed, which made it easier to finally abandon the idea.
But like I said, I'll bet I'm not the only guy here who's had that kind of brush with almost throwing a fair amount of money at a tool I neither needed nor could fit onto a bench.
