Toolmobile Drawer Rollers
dogvalley
Reno Nevada area
I just bought this toolmobile and "discovered" this forum while looking for parts. It is in sweet shape but just missing 4 of the 6 rollers on the rear of the drawers. The casters appear to be original but the side handles seem to be added on. I am looking for any ideas, recommendations or sources for these rollers, so any help is appreciated.
I have always had an appreciation for older hand tools and have acquired a modest collection that are mostly in boxes and drawers in different places. But after seeing how many of you attempt to fill sets and display your collections, I am inspired to dig mine out and see what all I have. Many are from my grandpa and dad but most are from yard sales and such.
Beside the toolmobile, I picked up a 12 piece Proto easy out set for $3.00!
Anyway, I hope you enjoy the photographs and appreciate any help in finding rollers.
montanafordman
Meridian, ID
Nice toolmobile! I wish I could help you with the rollers.. You could probably find a very small ball bearing with the right outside dimensions and fab a fixed stub axle to the drawer and find a way to bond, stake, or braze it to the inside of the bearing? :confused: The toolmobile was made by pressteel who also made some rollers for craftsman I think... you could try and find parts off of a donor? (also hard to find). Another less desirable and less durable solution is to find a way to attach some rollers from a common kitchen or dresser drawer (which will likely not have an actual bearing and be made of plastic). Very cool anyway. I also have a Plomb toolmobile. I suspect yours might be earlier than mine as your logo is painted on where mine is stamped into the metal.
Here is a post of my toolmobile.
http://www.garagejournal.com/forum/showthread.php?p=3717906#post3717906
A 1" OD bearing, and any ID you can get a small bolt through will work. You may need to grind the head of the bolt flat(er) to clear.
And you **** for that roller. :sad:
Yes they did. it was Craftsman's best roller (5 drawers! no "garage!) in 1954. I have one of them.
those rollers look very similar to inline skate wheel bearings....
:beer:
Skate wheels are some odd metric size I believe. The rollers need to be 1" exactly to fit right and have the "Slam locks" retain them. (there are two "keeper" tabs slightly smaller that 1" to keep the drawer from over extending you have to slam them past to get the drawer out... :dunno:
D
dogvalley
Reno Nevada area
Thanks to all who came up with ideas for the roller repair. Graingers actually has some steel one that may work, but they're ordered and won't be in for a few days. Will keep you posted
stormking
Nice Box. Yours is from 1946-1947, the embossed version is earlier. It should also have a bottom cover.
Steven67fr
Gilbert
Dang, that box is beautiful. I'd have paid $300+ for that if I found it... that's neat that it's the later painted logo (and still in decent shape) all the earlier ones were stamped in.
Good score!
D
dogvalley
Reno Nevada area
Things worked out better than expected. Turns out the bearings I had ordered from Graingers were the wrong size so I played a hunch and went to Napa Auto Parts. There I picked up bearing # 608 2Z which is almost a perfect match. The center is almost 5/16 dia. which allowed the threaded insert to fit inside and still keep a very low profile on the outside. A small 1/4 x 1/2 hex head bolt from the inside and a little Loctite semi-perm did the trick!
The bottom drawer stuck a little bit on the protruding bolt end but that was resolved by placing a thin flat washer inside the mount.
This problem has been solved and I have a very SWEET Toolmobile.
Many thanks to all of you who offered help and advice, plus I am honored to have received a "You ****" on my very first posting. Now I will prepare a new post on this weeks score..
