danielbuck
- Joined
- Apr 15, 2014
- Messages
- 921
I only have 110 power in the house that I am renting, and all of the breakers are 15amp. I find I'm tripping the breaker quite often while welding in the garage when I have the power turned up, particularly while stick/arc welding. If I turn the power down it doesn't pop so quickly, but with 110, I usually need all the power I can get.
Both of my welding machines are dual voltage, capable of being plugged into 110 and 220 with different cables. I invested in that when I purchased them, knowing I would eventually want/have 220 power.
I really don't know much about electricity. At the very least I would like to upgrade the breaker and/or wiring to have a more reliable 110 power with more amps, so that I don't keep popping the breaker all the time. But ideally I'd like to ALSO put in a 50 amp 220 into the garage.
I'd like to get a better idea of what is involved to make this happen, before I bring it up with my landlord to try and get his permission to proceed, and before I call an electrition to get an estimate. And I'd rather have an electrition do the work, to make sure it's done safely/properly and up to code.
The breaker panel is not in the garage, it's about 10 feet from the back of the garage. on the side of the house. Garage and house share one wall, but no doors or windows shared.
Is this a fairly simple task for an electrition? or is it involved? I believe the house (and probably all of the wiring) is from the 1950s, a small 2 bedroom house with gas appliances and only 110 15amp power.
It's not exactly something you can do on a whim. I am lucky to have found a place with a garage in a fairly nice neighborhood that I can afford that is close by my work, and a landlord that doesn't mind me taking apart my jeeps in the driveway. No way I'd consider trying to move elsewhere any time soon unless I get a nice raise at work.
