Jwych
im in the market for a 1/2" torque wrench, and there are alot of choices! anyone got any input in an affordable one?
If its occassiannal use, for home, harbor freight $10 works nicely.
Husky sells a USA-made one very similar to the Gearwrench models...I think it's $60-70.
HF ones are great for the price.
Totally affordable. Only $20 a week
Every week
Forever.
https://scontent-a-ord.**.fbcdn.net/hphotos-ash3/v/t1.0-9/1660739_775883439090079_1881096520_n.jpg?oh=32f36f2914dbf207ef3345d3067e1b29&oe=53CB6A69
Definitely agree.....the 1/2" Husky is IDENTICAL to the MATCO one, and it is only $85 I think. I just was looking at it tonight at Home Depot.
Husky $85 ---> http://www.homedepot.com/p/Husky-1-2-in-Click-Torque-Wrench-H2DTW/202916180
MATCO $316 ---> http://www.matcotools.com/catalog/product/TRC250A/1-2-drive-torque-wrench/
SAME EXACT TORQUE WRENCH!!!
Rubber comfort grip, don't know if it's the same grip under it.Does the Husky have a knurled metal grip?
Every week
Forever.
Big no for me on the Harbor Freight torque wrenches. I bought one during the recent tent sale for $9.99, and it did not work period.
I was sucked in by the Car Craft magazine article that's posted on the Harbor Freight website, but I think that wrench was cherry picked now.
Well, I'm off of work today so I decided to toss in some info for this thread.
Note - I'm not saying this is a scientific test, just that this is some casual data gathering by a DIY'er.
Also, how you pull can really affect the consistency of this torque wrench. A slow, steady solid pull that completes the clicking cycle seems to give me the best accuracy.
Anyway, here's what I did:
This torque wrench is about 5 years old and has been used a lot by me over the years to torque wheels and suspension parts. I also own CDI and Armstrong clicker torque wrenches and a couple beam torque wrenches.
I'm trying to give an honest perception of how the torque wrench works, good and bad, so I'll tell you exactly what I did.
I used my car as a testing device:
First, I decided to do a bunch of pulls to see how the consistency changed after several cycles. (All cycles performed with wrench set at 70 ft-lbs)
I didn't set the parking brake securely enough right off the bat and the car moved a lot on the first two pulls, which netted these low results. I actually would discount these, as I think it's my fault for not securing the car well, which gave inaccurate pulls that didn't follow through the click. But, to be fair, I included them:
65.7
65.4
The car was then better stabilized and I went through a number of cycles. Here's what I got:
67.9
66.9
66.3
67.2
69.7
70.2
68.3
68.2
68.9
68.3
69.1
67.8
69.9
69.5
69.3
69.9
69.5
Then, I ran the torque wrench all the way up and down and cycled it several more times. (NOTE - It's starting to get difficult to twist the grip on the this torque wrench sometimes. It may be reaching the end of it's usable life at 5 years and lots of use).
I then got these results (NOTE - these were all good, solid pulls that follow through the click):
69.9
70.6
69.2
69.8
71.0
71.0
68.4
70.6
Conclusions - If you can even take any conclusions from this unscientific example:
-Cycling the wrench does seem to help its accuracy and consistency.
-Consistent pulls that follow though the clicking cycle (for lack of a better term) give more accurate readings, in my case.
-This torque wrench is more than accurate enough for my needs.
-The HF torque adapter is a very interesting little tool that I've used quite a bit. I would encourage any serious DIY'ers to pick up a torque adapter. They're available from brands like Eastwood, Alltrade and I'm sure others.
-A torque adapter may be worth it's purchase price just to show a person how much their pulling method can affect the final applied torque.
Can't go wrong with the Husky USA. As stated, same wrench Matco sells at a fraction of the cost.
So you got a broken one. You know they have a lifetime warranty, right?
Just exchange it. I have four HF torque wrenches (two 1/2", and two 1/4" and all work great).
In what way did it "not work"?
I don't believe the Car Crafts wrench was cherry picked. My HF torque wrench has been used for years and is still accurate and within specification.
the husky and matco ones look strikingly similar to a 1/2 armstrong i have with a blue knurled handle, works very well and i semi regularly verify my torque wrenches at work, and are pretty spot on
Mine gives the same readings as my snap on, it's just annoying to adjust.
Out of curiosity from the suggestions here and I think ihateminumumwage you did a preview thread on the Husky 1/2" USA tw a little while back, I went and picked up one this morning at my HD. $84.97 listed, <$80 otd w/discount.
How did you get a discount?
The CDI 1/2" 2503MFR is the next one on my list: http://www.amazon.com/dp/B002LA1EDO/?tag=atomicindus08-20
I've got the CDI 3/8" 752MFR that I am pleased with: http://www.amazon.com/dp/B002L9Z27E/?tag=atomicindus08-20
What's that? Newer styled techwrench/techangle? I bought a techwrench not long after they came out. Those things are sweet, though I do wish I had the techangle instead.
I've been thinking of trading my TechAngles in for the newer versions, but I'm still on the fence. The light bar is nice if you can't see the digital screen, but I like the slimness of mine.
How's the battery life on it?
Be aware that some of the newer car fasteners need to be torqued to "X" foot-pounds, then plus "Y" degrees, when looking for a torque wrench.
I believe they are called torque to yield..
If you're really concerned about the angle you could use a p.o.s. plastic protractor; I got a couple hanging around. Easy to pick up during back to school time for around 50 cents, not much more during the year though.
