msgross
amazing work and documentation, thanks... of course I just wasted a day at work looking through this!
Most likely you could have had most of the house done by the amount you've spend on tools, but it would not have been up to your standard. Great work!
If this explanation doesn't work let me know and I'll set up a model with some pictures.
Please some more info. It sounds interesting, but I don't really get it.![]()
I also went to Harbor Fright with the intention of buying a shop press but I just couldn't do it. It was super cheap but then it was also super cheap. There's just something about a lot of (everything?) there that doesn't seem worth the time to remake in order to make it useable. I'll make a press down the road and do a nicer job but for now I just couldn't accept the sloppy build of it. Anyone have experience with hydraulics? I'm hoping to build a 20T press but with a hand pump instead of the ubiquitous bottle jack.
Thanks.
Gregor, you have that angle transfer device on your kapex (left side of the base). Coping is still better for inside corners, but you can use the angle transfer tool on outside corners.
That Woodpecker square has been a great help in keeping things square. Anyway, once the doors were cut allowing for the 3mm edge that I'd planned I couldn't stain or drill the holes for the cup hinges until that showed up.
After seeing this photo I searched for one of those squares only to learn of Woodpecker's one time tool program. I purchased their 1281 square and 24" T and they're beautiful.
Is that square your method for squaring your MFT or are you squaring to the holes via dogs?
Thanks
Gregor, watches too? It's like you intentionally choose hobbies that want to eat all of your time (bikes, tools, photography - OK, that one's work, but same problem). Looks like you're pretty handy with a case opener, do you do much internal work? Those Seikos can have a lot of fun options to customize if you have the steady fingers for it. I learned the hard way that I do not.
I don't understand the use of pocket screws here.
Will the screw holes continue to be exposed?
Now I feel this urge to learn what it takes to customize Seiko watches... BTW, That is a beautiful little hammer too.
I'm just continiously wondering where you get the time to work on these things. Two kids, restoring a house, make money to pay for it all and still have little side projects. You must have no friends, no sports and Judiaann has to be doing all the household. Or you sleep less then I do, or just have more hours in a day, or you make very good money and don't need to work as much as normal people do.
Quick question about the track saw, does it come with its own systainer? If so what size is it? Ive looked but haven't been able to find a good answer
Yes, it comes with a systainer Sys 4. http://www.amazon.com/Festool-TS-55-EQ-Circular/dp/B004XJYML2#productDetails
Tim
Gregor's got a TS75 that comes in a sys 5.
http://www.amazon.com/dp/B004XJYML2/?tag=atomicindus08-20
