quiet compressor
sracer99
Looking for recommendations on a 60 gal vertical, 220/1P, probably 5 HP compressor. Due to location in attached garage quiet is a big consideration. suggestions?
jomobco
Denver, CO
I just got my Quincy 7.5 horse 2 stage hooked up and it's much more quiet than my old single stage husky it replaced. I would imagine the 5 horse Quincy is even more so.
GlenC
Downey, CA
The quieter you go the more it will cost. The best way to go is with a direct drive piston compressor with a quiet box on it. Totally enclose the compressor and motor inside a box with sound absorption foam, and proper ventilation. They can be extremely quiet when properly constructed.
Rossco
Great White North
Yeah, the only 60 gal direct drive Comps av seen with box are Kaeser Ind & Eurocomp piston.
Hella $$$$ and not legal here in Canada.
Hundojoe
Minnesota
Sorry, not trying to hijack the thread, but I'm really courious as to why the Kaeser compressors are not legal in Canada?
vonhef
Southern, Ok
I have a 1957 Curtis compressor that is quiet. The key is the rpm the pump turns. Usually the slower the rpm the quieter. The Curtis C90 on my compressor turns 500 rpm.
volleyball
NY, not NYC
What is quiet? In a shop, you don't need whisper quiet, just not oil less noisy. Just about any cast iron pump will be quiet enough. Noise cancelling foam on the wall or sound deadening insulation also helps. Not having ridged connection to pipe or floor helps.
rlitman
Long Island
I think he's concerned with noise getting into the attached house.
The noise from oilless requires hearing protection, but while other compressors are quiet enough to not, they still overpower the TV.
The suggestions above are a good start. I would be sure the feet are isolated from the structure, to minimize conducted sound.
38Chevy454
Cincinnati, OH
Slower compressor speed = less noise; cast iron compressor = less noise; belt driven = less noise; rubber isolators on mounting feet = less noise; move air intake away = less noise; flexible hose connection = less noise.
volleyball
NY, not NYC
Yes, another question with no information. I don't like to assume the OP meant anything.
That leads to post like build a compressor room 100' away, run power out and air back in underground, add wiring for internet, phone and alarm. And since you did all that, add a 40 x 60 garage.
DenisG
Milwaukee
There's a 5HP Quincy 60 gallon air compressor with a 75 dBA rating, but it seems to be a discontinued product on Amazon:
http://www.air-compressor-reviews.net/quincy-2v41c60vc-review/
(50,000 hr pump life seems like a good selling point)
I'm not sure why it was discontinued, what model compressor could have replaced it, or if it's available somewhere other than Amazon.
Quincy also has an Xtreme series (60s dBA range), but prices start out at ~ $6k.
kbs2244
Most compressor noise comes from the inlet.
Take off the small, useless, filter and plumb in a small car muffler.
If you run a dusty shop, plumb in a small car air filter.
It will be about as noisy as a small car.
Durka
Howell, MI
I wouldn't call it useless. Perhaps all that garbage you suggest is ?
big.jim
derbyshire uk
i run a hydovane , direct drive vane compressor no thump thump can stand at side of it and hold a conversation
Todd.Brock
Cincinnati
I have a 2 gallon cman that takes oil. It's not always about oil/oilless. More direct drive vs. in direct drive ( belt or no belt ). That thing is loud as hell.
My old Champion 2 stage cast iron pumps were much quieter. I had an IR 2 stage 80gal. It was louder than champion. The pitch was lower on the champion and it was not as obnoxious.
Durka
Howell, MI
Yea Champions run at much lower rpms. Some in the 8 or 900 range vs a lower grade IR that runs at 3400 rpms. Champions are 3 times the machine vs the IR... IR's budget compressors anyway.
I have a little Porter Cable pancake compressor that you need ear muffs with. Man is that thing a screamer.
Rossco
Great White North
That Belair is a beauty. But very $$$$ and its 80gal.
Just don't think you can buy a sub 80 gal that ticks all the boxes.
