RedBKM
Let me start by saying this is on a farm tractor and not a school bus. A functioning repair is all that is required.
The steering ram end has about 3/4" of play and the seal is completely gone. It is not threaded on and replacement requires a cylinder rebuild and a new piston with rod end attached. Parts alone are nearly $400!
Is there an easier way to fix this? My cylinder is in good shape and I'm thinking I can weld on a new rod end and go. Has anyone tried this? Is there a place that sells a universal weld-on rod end?
This, or weld on a threaded coupling that could then accept a common rod end. Depending on what tools you have available. I've done the 2nd before. Never what AP mentioned, but that would work no doubt.
