NewShockerGuy
About to install wood floors. Looking for pointers and help (UPDATED)
I have 55 boxes of hardwood sitting in the house now since Saturday.
When we moved into the house two years ago and we had the same guy install the wood floors in the main area that did my wife's townhouse. I think we got it for around $6.90 installed per sq ft.
Welp, called him back to get a quote and it was too high this time so I said why don't I do it. The plus is that it's for our 4 bedrooms upstairs so there is NO rush in terms of it has to get done since we really are using just the master bed room. Like most installers he installed shoe trim molding. I hate how this looks, so for the first bedroom I've completely taken off all baseboards.
So there is previous wood in the hallway that was installed and since each bedroom has/had carpet there is a small piece of wood via a transition piece. I'd like to keep this transition piece instead of ripping it up and the 14-15 boards in order to extend the wood in the bed room for a single look. I like the separated look honestly.
My first question which may sound super dumb is how exactly do I do my first line and make sure it's plum. I know I will need to nail the first 2-3 rows by hand which is fine but I want to make sure it's straight.
Such as | | | |
Rather than ||| \ \ \
Hope that makes sense. IE: I don't want to think I'm starting straight then come to find out that by time I get to the other side of the room it's going to be all slanted or I have to cut the board and have some weird angle..etc
I would like to position the wood so that it is pretty inline with the boards already there minus the transition piece.
I have attached images on what I mean. If I put it up against the wall by the door then the pieces are some what staggered instead of pretty straight. But if I do it coming off the pieces then the wall side would only be about a 2" piece of wood? I would manually nail that down obviously but is that recommended? Would I nail that FIRST then the 2-3 more rows then start using the staplier or would I start with those pieces coming from the door then move towards the walls?
The next point I want to ask about is the spacing. Am I correct in assuming that there has to be a gap all the way around the room. Not just north and south if installing the wood. 1/4" or a little less all the way around. I took two photos. One is oof the wood right up against the wall, the other is pulled back some, the baseboard WILL cover the gap but I just want to make sure how the gap needs to be applied via all 4 walls or just front and back?
I have taken some pictures and just playing with the wood. In no way am I going to have the wood like that, it's going to be staggered obviously and the wood mixed in. What's in the picture is darker than most of the other wood in the boxes so I'm not going to transition the darker wood right off the original wood since it looks odd to me.
I think that's all the questions I have, it's really mainly the getting the plumb line and how to even get that going first since I know no walls are going to be 100% true, I just don't want to do an initial measurement by going off the wall only to find out I've f'ed myself. I did that mistake with wallpaper once and had to completely take down and redo because instead of doing a plumb line in the middle of the wall (which was easier because I could use a level and then draw a straight line) I went off a wall that by time I got to the middle wall everything was off...arg! lol
Any tips or tricks and advice would be great. I watched a ton of youtube videos but some things obviously aren't that clear.
Thanks,
-Nigel
Such as | | | |
Thanks,
-Nigel
