bczygan
So I have this very nice and solid table top.
It obviously came out of a school, where it was a workbench top and had at least a couple of vises mounted on the corners.
The top is 2 3/16" thick and 4'4" x 4'0".
This top is too big for my use, but could be useful if I cut it in half. I would cut it parallel with the boards that make up the top.
At the ends of the top, aluminum channels are let into the ends of the boards and are screwed in from the bottom.
I have attached some photos showing the overall top as well as closeup photos showing details.
In cutting this top in two, I am facing a few problems.
First, I am finding it impossible to remove the screws that hod on the aluminum channel. They are slotted flat head and 5/8" diameter at the top. My largest screwdriver is way smaller at the tip. And I suspect that even the right size one won't work. What other options are there?
Now, I am thinking that it might not be necessary to remove all these screws and the aluminum channel. If I can cut through the channel, only the one screw on each end, that is in the middle, need be removed. Can I use a typical circular saw to cut through an aluminum channel and a 2 3/16 thick hard wood top?
The last problem is that I suspect that the individual boards in this top are held together by threaded rod and nuts and washers. 10" from each corner are what appears to be a plug.
So how do I handle this? Do I try to cut through it with the circular saw? Or do I drill out the plug and remove the rods before cutting?
Note: Top is bottom side up in the photos.
Bill
Bill
