FINAL EDIT: Deals are dead. No more beating Amazon prices. What all did you guys score? And how many 7/32" GearWrench pass-thu sockets did you end up with? Let's see some pics!
Edit again: These are no longer showing up as giving the 15% savings on Amazon price-match items but lucky for us if you add an .84 cent Gearwrench pass-through socket to your cart, all of your other Amazon price-match items suddenly get 15% cheaper!
(old EDIT): I'm just gonna keep updating the OP with a few links to some stuff I come across if anyone's interested. 15% off Amazon pricing plus coupons is pretty sweet deal for some items. These are really just examples, there are a lot of other coupon-friendly Amazon price-match items with an extra 15% off. I'm just posting the Sears prices assuming SAVE15 but you might find a better coupon combo. I think today is the last day for these deals?
Gearwrench:
GearWrench 3 Pc. Cushion Grip Teardrop Ratchet Set - 1/4, 3/8 and 1/2 in. Drive Amazon: $111.61 Sears: $79.87 (w/SAVE15)
GearWrench 56 Pc. 3/8" Drive SAE/Metric 6 Pt. Standard & Deep Socket Set Amazon: $130.29 Sears: $95.75 (w/SAVE15)
Armstrong
Armstrong 18 pc. 12 pt. Metric Full Polish Long Combination Wrench Set in Vinyl Roll Pouch Amazon: $383.66 Sears: $291.11 (w/SEARS35OFF300)
Armstrong 12 pc. 3/8 in. dr. Crowfoot Wrench Set Amazon: $163.50 Sears: $123.12 (w/SAVE15)
Armstrong 14 pc. 6 pt. 1/2 in. dr. Impact Socket Set Amazon: $99.71 Sears: $69.75 (w/SAVE15)
Armstrong 3/8 in. dr. 50-250 in/lb. Micrometer Adjustable Torque Wrench with Ratchet Hea Amazon: $183.80 Sears: $141.23 (w/SAVE15)
Armstrong 7 pc. SAE Ratcheting Flare Nut Wrench Set Amazon: $205.43 Sears: $156.62 (w/SAVE15)
Armstrong 3/8 in. dr. 50-250 in/lb. Micrometer Adjustable Torque Wrench Amazon: $183.79 Sears: $141.22 (w/SAVE15)
Armstrong 1/4 in. dr. 30-200 in/lb Micrometer Adjustable Torque Wrench Amazon: $153.80 Sears: $115.73 (w/SAVE15)
OTC
OTC 6550PRO PROFESSIONAL MASTER FUEL INJECTOR FITTING KIT Amazon: $331.93 Sears: $267.14 (w/SAVE15)
OTC 1513B Stinger 4 Ton Collision Repair Set Amazon: $173.94 Sears: $147.85 and coupon friendly ($132.85 w/SAVE15)
OTC 4526 HEAVY DUTY SINGLE PRESSURE BEAM BEARING SPLITTER Amazon: $148.65 Sears: $111.35 w/SAVE15
OTC 4532 7 TON - MULTI-PURPOSE BEARING AND PULLEY PULLER KIT Amazon: $130.32 Sears: $95.77 w/SAVE15
OTC 6668 HARMONIC BALANCER PULLER KIT Amazon: $104.40 Sears: $73.74 w/SAVE15[/QUOTE]
Mastercool
Mastercool HEATED DIODE ELECTRONIC LEAK DETECTOR W/UV LIGHT Amazon: $208.27 Sears: $162.03 (w/SAVE15)
Mastercool CRIMPER A/C HOSE HYDRA-KRIMP Amazon: $563.35 Sears: $443.85 on Sears (w/SEARS35OFF300)
KASTAR
Kastar 12-pc. Combination Int/Ext Retaining Ring Pliers Set Amazon: $81.34 Sears: $69.14 (add $5.86 worth of fillers and use SAVE15 to get $15 off)
Central Tools
Central Tools Sleeve Height & Counterbore Gage Amazon: $157.78 Sears: $119.11 (w/SAVE15)
Virax:
Virax HM Piezo Propane Torch Amazon: $132.88 Sears: $97.95 (w/SAVE15)
Virax 18" Rapid Pipe Wrench Amazon: $56.19 Sears: Use some fillers to get to $75 so you can use SAVE15, should work out to about $40 for the wrench
Chicago Pneumatic
Chicago Pneumatic Screwdriver 800 Rpm Amazon: $311.00 Sears: $249.35 (w/SAVE15) I believe this tool is made in Japan
Chicago Pneumatic 1/2" Dr. IMPACT WRENCH Amazon: $179.24 Sears: $137.35 (w/SAVE15) I believe this tool is made in china or Taiwan
Chicago Pneumatic 1/2" Carbon Fiber Impact Wrench - Comfort & Power Amazon: $267.80 Sears $212.63 (w/SAVE15) Not sure the COO
Chicago Pneumatic 3/4" Drive IMPACT WRENCH Amazon: $360.66 Sears: $271.56 (w/SEAR35OFF300) I believe this is made in Japan
Chicago Pneumatic LIGHT WEIGHT MAGNESIUM 1/2" IMPACT Amazon: $234.29 Sears: $184.15 (w/SAVE15) Not sure COO
Florida Pneumatic
Florida Pneumatic Mfg FP-750K Die Grinder Kit Amazon: $58.89 Sears: Use some fillers to get to $75 so you can use SAVE15, should work out to about $42 for the grinder
Lisle
Lisle SEAL DRIVER KIT 18 PC UP TO 3-3/8IN. Amazon: $35.22 Sears: $29.94 & coupon friendly
Lisle CREEPER RED LOW PROFILE Amazon: $64.71 Sears: $55.00 and coupon friendly
Lisle DISC BRAKE CALIPER TOOL REAR 6 PCS Amazon: $65.72 Sears: $55.86 & coup friendly
Lisle MASTER PNEUMATIC BEARING RACE & SEAL DRIVER SET Amazon: $90.95 Sears: $62.31 (w/SAVE15)
Lisle PINION BEARING RACE DRIVE SET Amazon: $102.72 Sears: $87.31 and coup friendly!
Lisle COMBINATION FLARING TOOL Amazon: $87.26 Sears: $74.17 & coup friendly
Lincoln Grease Guns
Lincoln AIR HOSE REEL ASSM 50' x 3/8" Amazon: $134.78 Sears: $99.56 (w/SAVE15)
Lincoln Heavy Duty Leaver Action Fluid Pump Amazon: $70.28 Sears: $59.74 & coup friendly
Lincoln 2 Way Loading Lever Action Manual Grease Gun Amazon: $32.80 Sears: $27.88 and Coup Friendly
Lincoln 14.4 VOLT POWERLUBE KIT - 2 BATTERY Amazon: $219.94 Sears: $186.95 & coup friendly
Lincoln Grease Gun, Super Heavy-Duty Pistol Grip Develops up to 7500 PSI Amazon: $33.99 Sears: $28.89 & coup friendly
Lincoln GREASE GUN CORDLESS WITH CASE, TWO BATTERIES Amazon: $172.99 Sears: $147.04 & coup friendly
Posi-Lock
(original post)
I just discovered that Sears is offering an additional 15% off of multiple tools they've already price-matched with Amazon.
This is basically unprecedented. Sears never allows additional discounts on Amazon price-match items. Even during Sears friends & family events (20% back in points etc.) the price-matched items were excluded and Amazon price-matched items are also usually not coupon friendly but right now they are!
So between 15% off, coupons, cash back and whatever deals you can sneak in, there are some seriously good deals right now...everything from specialty auto tools to power tools, this is a great chance to save some dough on name brands.
Let me know what you guys came up with
Gearwrench:
Armstrong
OTC
Mastercool
KASTAR
Central Tools
Virax:
Chicago Pneumatic
Florida Pneumatic
Lisle
Lincoln Grease Guns
Posi-Lock
(original post)
) Anyway point is lately I've been getting significantly (15% or more is my margin for significant) better deals from sears for stuff I like to spend money on and throw in a drawer...just gotta play the game.
