As promised, pictures, I'm only 17 so the large percentage of the tools are almost twice my age, and will still most likely out love me, hopefully everybody can enjoy.
Sockets; 1/4 drive are Repco, 3/8 are new Sidchrome, 1/2" are all Australian Sidchrome, Snap On SL80A 1/2" ratchet, FLF80 3/8" ratchet, TF72 1/4" ratchet, have an Australian Sidchrome 3/8 round head on the way.
Mostly Sutton Slot and Centre Drills in the left, few P&N 3 flutes, two P&N tee handle tap wrenches, in the middle is a cheap pair of digital calipers, Mitutoyo Micrometers to 100mm, Mitutoyo dial calipers, Toledo machinist square, and some starrett small hole gauges, on the right is all P&N #1 Morse taper drills and reamers, odd Sutton fractional drills, Warren and Brown 3/8 torque wrench, Sutton pin punches, Moore and Wright drift
Aussie sidchrome pliers, Eclipse vice grips, no name long handle offset needle noses, Australian Stanley screwdrivers, off hex keys and inhex sockets, there's some Gedore and Stahlwille in there though.
Snap On flank drive plus metric combinations, 10-24 + 27mm, Gedore 26mm, Australian Sidchrome 22series 30mm combination, 8-36 Aussie Sidchrome double rings, 8-30 Sidchrome double open Enders, have a full set of 22 series combos at work.
Full set of Swedish Sidchrome shifters,4"-18", 5/16-1 1/4 Aussie Sidchrome double rings, Sidchrome double opens 1/4-1 1/16, Flat Sidchrome double rings 3/8-11/16, 3-4x1 Sidchrome line wrench,
Nicholson files, big Stanley screwdrivers, all Sidchrome extensions and ratchets, all the 1/2" stuff is Aussie.
All kinds of odd stuff, Stahlwille Ball pein hammer, Estwing Claw hammer, Sandvik hacksaw, Australian Sidchrome 3/4" Sliding T, Stahlwille 36mm socket, other odd fractional sockets I use, have a full set of metric at work, Gilbow and Wiss tin snips, Odd shifters, Sidchrome 1/8-3/4 Whitworth double rings, open Enders in cupboard, Dowidat 3/4 combination, Dowidat 36mm combination, Stahlwille 30x32 double ring
Dawn 5" offset vice, made in Australia, need to get around to making a decent bench to bolt it to. 46mm P&N taper shank drill somewhere in the background
Mostly Australian Sutton/P&N taps and dies, from M3-27mm, and 1/8-1",in taper, intermediate and bottoming, UNC and UNF intermediate taps from 3/16-1", pipe and hydraulic taps to 3/4BSP, odd BSF taps, some Dormer thrown in, P&N BA tap and die set inside, Taper shank drills from 14.5-30mm
Another tool board of Aussie Sidchrome spanners, would probably sell these if anybody is interested.
