You don't really plan on reusing the U-bolts, anyway, right? Those should always be replaced.
I always get new u bolts. I torqued them down last summer when I did some work. I'll angle grind them off though.
Bro, you must be confused with something else. The milwaukee fuel m18 has more power than anything on the market right now.
Their 1/2 full size impact has 1100ft/lbs reverse. I own it and it's no BS. It makes most Air impacts look like toys.
I know what I have. If it is supposed to have 1100 ft lbs, then the one I have is broken. But milwaukee service and warranty is garbage. They wouldn't replace a battery that was under a week old and wouldn't charge. Said I probably misused it or charged it at an improper voltage.
The impact driver doesn't have the power of my XRP dewalt. As it won't pull a 1.5" knock out through using a 1" socket, but my XRP will pull a 2" knock out through.
The circular saw guard catches on EVERYTHING thinner than a 2x4.
And the stupid things won't charge when it's cold out. Not that the charger likes genset power much anyways, so half the time it doesn't work anyways. These are 20 kilowatt generators to megawatt generators.
I bought a lot of the M18 fuel tools (Only one I don't have is the compact impact wrench) to replace my aging dewalt xrp li-on tools, that have been abused like crazy and still work, and when they do break I have never had an issue getting it fixed or replaced under warranty even when the last time I bought a tool or battery was 4 years ago.
So after buying such a huge amount in tools, it should be no wonder I am not happy with them after garbage service and lack luster performance.
I'll take my impact wrench in today and see what they say.
He obviously is, or is just a fanboy for the yellow, orange, green, or blue tools.
I really wanted to like the M18 tools, the battery gauge is enough for me to want to switch. And while the sawzall, angle grinder, and drill are basically the same as my dewalt but red. The impact driver just isn't up to the task like my dewalt, and the circular saw guard catching is just a huge piss off all the time.
