Curtain, divider, track options
bedn0009
Hudson, Wisconsin U.S.A.
Hello,
I am planning a 32 x 28 x 9 build for later this summer. In the garage I plan to do some woodworking and subsequently HVLP paint spraying and finishing (as well as storage).
I want to set up a section in the middle of my garage that I can section off to control overspray, dust, etc. For the curtain portion of this, I plan to use a heavy recycled billboard tarp: http://www.billboardtarps.com/collections/tarps.
What I'd like input on is any suggestions/recommendations for a track/bracket set up from which I can retract/open the curtain.
When not in use, I plan to push the curtain "bundled" up against one of the walls.
Anyone have any suggestions? Is this is a Unistrut application?
Thank you.
Norcal
Wonder if curtain track for hospital privacy curtains would work? Long straight lengths and curved sections are made. Being made for medical use though means it would not be cheap.
mikec35
NC
I ordered track curtain and rollers off ebay, just like they use in hospitals. Been researching curtains, I think I am going to get some Sports themed Full Size sheets as dividers, clip to the track rollers and add weights to the bottom. Cheaper than curtains
bookman51
Kearney, Nebraska
I got some material from a local canvas company last fall. They custom made the size, and they also sold me the rollers to pull it up (rather than to the side). I got the cord from FarmTek and a couple of hand crank wenches locally. The problem is that installing it I will be working about 15 feet up. I have been waiting on some help and some time to rent a lift to get it installed. The distance is about 40 feet wide by 15 feet high, and the material is in two pieces. I like the idea of it pulling up since it will be out of the way most of the year. The canvas company said they make them all the time and showed me a set up in their shop.
KaotiK TrendZ
Texas
I've been pondering the same idea. My thought I came up with, but haven't done yet is to screw eyelets in the ceiling. Get some conduit and put through the eyelets. Then buy some canvas paint tarps and put a few grommets on one side. Then buy cheap shower curtain plastic hooks to use to hang canvas from conduit. Can push open and close, and also take down easily if needed.
Pondered clear heavy mil plastic also instead of canvas.
ez-duzit
Marina del Rey
...My thought I came up with, but haven't done yet is to screw eyelets in the ceiling. Get some conduit and put through the eyelets. Then buy some canvas paint tarps and put a few grommets on one side. Then buy cheap shower curtain plastic hooks to use to hang canvas from conduit. Can push open and close, and also take down easily if needed...
You won't be able to slide the shower hooks very far with conduit hung by screw-eyes.
KaotiK TrendZ
Texas
I only need each side to be about 10'. Figured the conduit would be supportive enough and only need to slide one whole side. May have to tweak it some. Wish I had the money to have a spray booth haha.
78scotts
Minnesota
Just an idea, garage door track and wheels. If you put the flat side down the weight of the curtain might hold the wheels in place from popping out of the track.
mikec35
NC
I used canvas from Harbor Freight. It doesnt hang evenly, may be the way the canvas was cut. It is heavy as well.
KaotiK TrendZ
Texas
Well looks like my idea was a pile of poo doo doo haha. Well maybe plan B will work, hook up with a sugar momma and build a paint booth haha.
kevinklascanb
Long Beach, Ca
My wife buy these from Ikea and hang curtains with them. These come in 10 pack for $5.
http://www.ikea.com/us/en/catalog/products/80224096/
larry_g
oregon
http://www.jhusa.net/1500.aspx
You might consider pocket door hardware above. You can buy the track and rollers then afix the canvas to hang from them. I have this in my house and can attest the hardware is top quality.
lg
no neat sig line
shopnut
Florida
If you are going the shower ring route, you might consider these - they will roll rather than slide and will make moving a big curtain a lot easier.
shopnut
Florida
bookman51 - I would like to see what this looks like if you can offer any pictures. I have a rail at 15' just begging for a curtain. Thanks.
ez-duzit
Marina del Rey
I like those roller slides.
The trouble with a sliding curtain is that you would normally like to take a long span and slide the whole thing out of the way, in 1 or 2 gatherings. Rings sliding on a rod limits the maximum span because of rod deflection.
mikegt4
sw ohio
Today I stopped in at my son's work (he is the assist. mgr. of a body shop) to check the progress on my Ranger that was backed into last week. The have some bays with curtains like the OP wants. They are commercial units that use Uni-struts for rails (installed open side down) with sliding hooks for hanging the curtain. Seems to work pretty well.
plow
Louisiana
Too flimsey for BB material. I would use unistrut. They also sell a little carrage that rolls in it. Maybe some barn door hardware from tractor supply???
mikec35
NC
I'm using the hospital track you describe with heavy canvas drop cloths, works great, although the canvas cloths don't hang as neat as a curtain would.
Max Tout
I use a pair of 1-1/4 od sealed bearings with 3/8 bore. Get a 3/8 x 1-1/4 roll pin to serve as axel and make whatever configuration I need to hang curtain or door. This works inside 1-5/8 unitsrut for track and you have a great roller for about 6 bucks. I have 7'x 12' doors that have been rolling on these for 20 years
